My AC doens't blow cold, at least not consistently. Every once in a while it seems to blow a little cool, but for the most part it's ineffective. Would getting a $20 can of refrigerant at a place like AutoZone be an easy first step in trying to get it back to normal? I've heard that low refrigerant levels can prevent the compressor from even running. Are those products even compatible with a C5? The one I'm looking at is like $18.99 and has some sort of pressure gauge on the hose.
You run the risk of too much head pressure when you do not know how much refrigerant is in there.. it blows cold so you have some...
You should really have it evacuated and recharged to the proper amount, this also insure the right amount of oil...
Thanks ET. I'm still thinking of giving it a try if I can find the proper specs for pressure... any idea where I could find it? The recharge kit I've been looking at has a pressure guage, so I don't think there'd be much risk of overcharging.
Head pressure is a variant...I am no real expert but I know that ambient temperature plays a part in the calculation... here is a tip if you are set on doing this yourself... I would only put an ounce or two in at a time..then allow this to run through the system. the trick would be putting in enough to get you to were its cold, but you can easily over charge the system and blow the compressor. The problem is you do not know how much is in there..the other issue is : where is the leak?
Good points... thanks. You've got me leaning toward just letting a pro do it; maybe even the dealer. I have a warranty, so if they tell me it's a leak I assume it'd be covered.
I use a gauge on my automobiles. I purchased the gauge at Pep Boys for around $25.00. You do not want to overcharge the system. When you buy the refrigerant, make sure that it has oil in it. Refrig is also sold seperatly from the oil. You may have to add a can of the pressurized oil if your auto parts store does not sell, the refrigerent with the oil in it. All of this is based on the assumption that you are low on Freon. Hopefully thats the problem. Good Luck
Thanks in advance.
Pep boys /autozone / advance auto all sell two tools for check and recharge. One tool 14.99 is used to just check refrig pressure. Another tool-20.00 lets you attach the can of refrig and will give you the pressure read out as you have control over how much refrig is deliveried to the system. Adding a can of Refrig is ok but do not use the small cans of combined leak seal / charging oil/Refrig those are a possible problem per GM. Adding Refrig is no problem, but if you are requiring ReFrig you might have a leak that requires a Techn is look for the leak source and repair, o-rings, cracked nose, loose fitting, etc.
I tend to agree with this.
If your system IS low on refrig. then you have a leak that needs to be fixed. Adding more refrig will only temporarlily make it work again.
You need to either borrow a gauge of buy one and check the pressure. If it's low, then you have a leak and you will need to get that repaired before adding more refrid. to the system.
If the pressure is normal; then you have a totally different problem.
I have used the recharge kits you speak of..they have a guage on them for pressure readings..in my experience as long as you are in the green you are ok...they recharge will last you about 6 mos MOL....I need mine fixed...not sure where it is leaking but the only quote I got so far was $1200 and having to pull the dash which I am not thrilled about. FWIW..the $25 to get you thru the summer is worth it
