3" exhaust question
Old Apr 8, 2006 | 08:26 AM
Blow Torch's Avatar
Blow Torch
Default 3" exhaust question
If I change out my 2 1/2 exhaust mid section (with x-pipe) for a 3" magnaflow x-pipe (running from 3" collctors to mufflers) will I lose any significant low end torque?
I had never heard of losing torque with a more efficent exhaust until someone posted it.
I have a crappy no name x-pipe and wanted to replace the sytem, but I don't want to sacrifice any low end torque for a few horses on top that I won't use very often.
Old Apr 8, 2006 | 09:02 AM
bobbss's Avatar
bobbss
I just got a new set of headers from the Vette Doctors.I was going to get the 3" mid pipes but they didn't recomend it unless you had a big cubic inch or F/I motor.The x part is 3" and then drops to 2.5".I got the off road pipe.
Old Apr 8, 2006 | 09:13 AM
6Speeder's Avatar
6Speeder
I didn't loose any low end torque. I gained power and torque throughout the power band.
Old Apr 8, 2006 | 11:59 AM
B42Old's Avatar
B42Old
5th Gear
The problem is what are you going to run as a catback??
Old Apr 8, 2006 | 01:41 PM
Blow Torch's Avatar
Blow Torch
I am running magnaflow mufflers and no cats now.
"The x part is 3" and then drops to 2.5".I got the off road pipe."
It seems like the "reduction" in pipe size would disrupt flow
I guess I just can't see the scientific logic behind losing torque by running a larger diameter mid-pipe. If you will gain hp by allowing the exhaust to flow better and do a better job of removing all burnt gases from the combustion chamber, then how do you lose torque?
Old Apr 8, 2006 | 05:17 PM
B42Old's Avatar
B42Old
5th Gear
I have a Forged 395 stroker with a D1SC, and 3" exhaust all the way out and I can't find a catback to bolt up to the exhaust except Random Tech's.
Old Apr 8, 2006 | 05:40 PM
peter pan's Avatar
peter pan
Life Time NCM #2196
Stainless works also makes a 3" catback and I have been looking at that and there 3" X-pipe to hook up to my FI ride
Old Apr 9, 2006 | 12:01 AM
allmee's Avatar
allmee
I was told by a custom muffler shop owner that your exhaust is only as good as it's smallest opening. I do not know what the size of the collectors at the end of the stock headers are, but if they are 2.5 inches and you go to 3 inches down the line, you are waisting your $!
This was his theory and it seems to make sense.
Old Apr 9, 2006 | 08:09 AM
Blow Torch's Avatar
Blow Torch
That is along the lines that I have been thinking;
The collectors are 3". I know the mufflers will slow the exhaust flow, but I would think an unubstructed flow to the mufflers would help.
To 3" exhaust question
