Poorboy Air Intake??
Old Apr 9, 2006 | 10:16 PM
2000 Torch's Avatar
2000 Torch
Default Poorboy Air Intake??
I have heard rumors of some Vette racers removing the stock Air Filter cover lid and zip tieing a K & N Air filter into the Air Filter housing base. Any words of wisdom?
Old Apr 9, 2006 | 10:46 PM
screw991le's Avatar
screw991le
From: Redsox, Pats, Celts & Bruins !!! Redsox Nation !!!
St. Jude Donor '06-'07-'08-'09-'10-'11-'12
Ahh the zip tie mod, do a search, you'll find 100s of opinions
Old Apr 10, 2006 | 01:51 AM
BAD FNZ's Avatar
BAD FNZ
I did it and it works great...
Old Apr 12, 2006 | 05:11 PM
jl240z's Avatar
jl240z
Default Air filter cover
Depends on what version of the cover you have. Some guys just took a hole saw & cut a symetrical pattern in the top side and reinstalled over the K&N. I think the top part contributes to holding the filter in place all along the four sides where just using tywraps could allow the edges of the filter to let air by where not held in place. But really you know you want an aftermarket system, so get yourself a present and save the original stuff in case you want to go back to stock. Join the mod squad
Old Apr 12, 2006 | 09:14 PM
Thrust NYC's Avatar
Thrust NYC
Corvettes and Pooboy's dont mix. Why buy an expensive car and put junk in it?
Old Apr 12, 2006 | 09:17 PM
Tiger 650's Avatar
Tiger 650
Buy a 02-04 Z06 Airbox top. Direct replacement and works great.
Old Apr 12, 2006 | 09:49 PM
screw991le's Avatar
screw991le
If you do that make sure you do the seal or water may be a problem
FOLDNTOP's Avatar
FOLDNTOP
From: Oakville ON "Real Corvettes have folding tops..."
I agree did that on mine.
Old Apr 13, 2006 | 12:42 AM
Oldvetter's Avatar
Oldvetter
Best $50 mod for un-modded engines. If it's good enough for 405 HP Z06, it's great for a stock LS1. Pre-2001 C5s will really benefit from this mod.
Old Apr 14, 2006 | 02:52 PM
VETTING's Avatar
VETTING
I just so happen to have a 2002 stock Z06 lid and K&N air filter to go with it. Less than 200 miles on them. I got a deal I could not pass up on a Blackwing and I'm quite happy with it. $75 plus shipping if your interested P.M. me.
Old Apr 21, 2006 | 03:28 AM
straatien's Avatar
straatien
I have this temporary modification on my '02 Z06 and it works great. I can totally tell by SOTP that it's gettin' somptin' from the increased air flow. I don't know if the K&N has anything to do with it as the discarded paper filter was filthy. Plus, there's a lot of argument about the K&Ns actually being no better or even slightly worse than paper. I'll be finding out first hand either way. In closing, I recommend this mod for those people saving up for something significant, e.g. SC/TT/Heads/Cam/etc.
Old Apr 21, 2006 | 06:32 PM
HeyFred's Avatar
HeyFred
Just finished my poorboy air box modification.
What I did different:
* Shortened the stock metal straps to hold the airfilter in place.
* Modified the original outer cover to help hold the air filter assembly in place.
Air filter comes out like factory or you can loosen the hose clamp at the throttle body and pull the complete airbox assembly. The original outer air box cover stays bolted to the car.
Next: Going to build a hood seal.
Keith
Old Apr 22, 2006 | 06:48 AM
straatien's Avatar
straatien
Keith, why use the outer airbox cover at all. I removed mine altogether.
Old Apr 22, 2006 | 02:58 PM
HeyFred's Avatar
HeyFred
I know, but I feel it helps to keep the assembly located under hard cornering. Just me wanting things to stay in place.
Went out and drove the car today. The engine seemed to pull harder and smoother while accellerating off low speed corners.
The car is just fun to drive so long as you respect it.
Keith
To Poorboy Air Intake??
