Rear Clunk
Old Apr 10, 2006 | 12:04 AM
remaley37's Avatar
remaley37
5th Gear
Default Rear Clunk
Any ideas?
I have a 99 C5 and there is a deep clunking noise coming from under the rear of the car.
I can't see anything obvious out of place. It's not all the time but seems to be increasing.
Any suggestions would be appreciated.
Old Apr 10, 2006 | 01:06 AM
Mike94ZLT1's Avatar
Mike94ZLT1
I just put my car back together and I have a funny clunk, 99 C5 as well!
Old Apr 10, 2006 | 10:09 AM
xlr8shn's Avatar
xlr8shn
Check to see if your car's upper control arms are hitting the shocks on the back of the car. (You will be able to because the control arm will wear/rub the paint of the shock absorber.)
My 99 Z51 was doing this until I replaced the shocks with bilsteins...
Old Apr 10, 2006 | 03:36 PM
FASST LN's Avatar
FASST LN
Check to see if possibly an exhaust hanger has broken and your catback is wiggling around.
Old Apr 10, 2006 | 04:55 PM
Derf's Avatar
Derf
Default Clunk
The solution is to loosen the rear hub nut (33mm) with a CV tool from Pepboys or autozone, etc. Then spray white litium grease (like WD40 but better) on the splines using the plastic straw. Do not remove it, just screw it off about 1 inch. Retorque and no more clunk.
There is a post on the forum, just search for "rear clunking noise".
Old Apr 27, 2006 | 08:33 PM
stngh8r's Avatar
stngh8r
i had some weird clunking stuff coming from my cars rear suspension and it just about drove me insane. I ended up buying a bunch of parts that i didnt need and didnt fix the problem. Then i put some grease on the sway bar end links just to check......Waa Laaa, no squeky, binding sway bar anymore!? I dunno
To Rear Clunk
