Cruise Control disengaged immediately
Old Apr 10, 2006 | 04:26 PM
BERGN8R's Avatar
BERGN8R
Default Cruise Control disengaged immediately
After having new 4.10 diff and clutch set up installed, my cruise control will not stay engaged. It displays like it is going to then immmediately disengages. Obviously I suspect something associated with the recent work but I have no trouble codes and everything else works. I even went ahead and changed the gear ratio using LS1Edit even though it shouldn't have an effect. It didn't help. I know depressing the clutch will disengage it, is there switch on the pedal or a pressure switch?
Old Apr 10, 2006 | 04:41 PM
white90conv's Avatar
white90conv
There are switches under both the clutch and brake pedals. People have noted problems with the adjustments of these switches. Try putting your foot under the pedal and pulling back when you engage the cruise control. If this makes it work, then one of the switches is out of adjustment.
