Engine Carbon Removal
Start the car and let it warm up.
Disconnect the PCV hose from the intake manifold on the passenger side just behind the throttle body.
Install a piece of hose to the manifold tube and insert a funnel in the other end. Hang the funnel from something under the hood and apply a clamp to the hose to restrict the flow of the cleaner into the engine to a slow rate - kind of like an IV drip you see on medical shows. A vise grip works well.
Start pouring the cleaner into the funnel and the vacuum from the engine will slowly pull it in. Don't go so fast that you stall the engine. It took about 10-15 minutes to get a can in at idle. The engine will lope and run rough which is about the correct rate of fluid.
When the cleaner is almost all used up, do a quick dump to stall the engine and then let it sit four about an hour minimum - over night is better.
After the wait, start her up and watch the smoke. I was too embarrassed to stay in my neighborhood so I took it out on the highway to blow it out. The smoke cleared after about five to ten miles. It really looks bad though when you first get going.
The rear end was covered with black soot and carbon from the draft. I couldn't believe how much junk blew out of a motor with 22K on it.
Have fun.
Have fun.
DH
Good shops use stronger chemicals and machines to clean carbon deposits. This is called a carbon depletion service and it is real. They are not just taking your money. If you run the 44K on a regular basis, there should be no need to have the more expensive carbon depletion service performed.
Never heard of it being offered from a dealer though!
