Code 10 PCM 1441
Old Apr 11, 2006 | 01:40 AM
SLPRC5's Avatar
SLPRC5
Default Code 10 PCM 1441
What is code 10PCM 1441. It sets the CK engine light. When I clear the code the CK eng light goes out. Could this be the cause of poor fuel milage?
Old Apr 11, 2006 | 10:10 PM
Silver98's Avatar
Silver98
P1441 Evaporative Emissions (EVAP) System Flow During Non-Purge-B
Not sure what the service manual directs for this code. I assume you have the Service Manual for your year, right?
Ciao
Old Apr 11, 2006 | 11:11 PM
Mr. Lucky's Avatar
Mr. Lucky
St. Jude Donor '06
If not, use this.
Old Apr 11, 2006 | 11:34 PM
SLPRC5's Avatar
SLPRC5
Originally Posted by Mr. Lucky
If not, use this.
Thanks for the LINK
The electrical plug was not plugged in. The plug on the solenoid on the driver's side near the firewall. After plugging it in..no CK engine light.
Maybe you can answer two questions for me.
first..with this unplugged would it affect gas mileage?
two..would it affect a tune while unplugged?
Because my mileage was down and it was tunned after mods with this plug not connected.
Thanks,
Rsty
Old Apr 11, 2006 | 11:50 PM
Mr. Lucky's Avatar
Mr. Lucky
St. Jude Donor '06
Check to see if you have a P0172 and/or P0175 History code. If so, that means the unplugged solenoid was causing a rich condition, which your tuner compensated for...and now that the original cause has been fixed, the net result would be that you may be running too lean. Either way, I don't think it would be a cause for poor mileage, since the tune would have compensated.
If you have already cleared the codes, unplug the solenoid again and drive around for 1/2 hour or so. Then check your stored codes. Alternatively, if you have some way of displaying or logging OBD-II data, drive around and note your part-throttle and steady speed LTFTs. If they are highly negative, it indicates a rich condition, and is just a matter of time before setting codes.
Bottom line... check with your tuner, but I don't think this is a big cause for concern.
Old Apr 12, 2006 | 12:54 AM
SLPRC5's Avatar
SLPRC5
Thanks again Mr. Lucky..I'm going back to the tuner because he is aware of the problem and a re tune is in order..
Rsty
To Code 10 PCM 1441
