Convertible top problems Need help
Old Apr 14, 2006 | 05:58 PM
CyberGSDude's Avatar
CyberGSDude
Default Convertible top problems Need help
Was going to take it to the dealer but decided to see if I could get some DIY help.
Problem #1 - Convertible top has left rub marks on the tonneau cover. How do you adjust and how do you know if your adjustment is then adequate?
Problem #2 - Passenger window corner rubbing on inside corner of top causing some fraying. Everytime you shut the door it its the top. How do you adjust this?
Thanks!
Chris
Old Apr 14, 2006 | 06:45 PM
rws.1's Avatar
rws.1
Chris PM me with your e-mail address. I 'll e-mail you a word doc that should help.
Rich
Old Apr 14, 2006 | 07:25 PM
RPOZ4Z's Avatar
RPOZ4Z
Cruise-In VII Veteran
you need the new updated rear weatherstrip.
it's called "window tip in", adjustment will be covered in the doc that rws.1 is going to send you.
Old Apr 14, 2006 | 08:32 PM
bobc997615's Avatar
bobc997615
http://www.c5forum.com/cgi-bin/ultim...ic/1/2213.html
vert top adjustment
Old Apr 14, 2006 | 09:30 PM
CyberGSDude
Thanks! I will try this.
Old Apr 15, 2006 | 10:01 PM
JD's C5's Avatar
JD's C5
ttt
Old Apr 15, 2006 | 10:49 PM
Roofless's Avatar
Roofless
St. Jude Donor '11,'13
I know th is sounds dumb but I had the problem of the top rubbing on the hatch also, I found that if I moved t he passenger seat forward a little before operating the top either up or down it cured the problem.
Old Apr 16, 2006 | 06:27 PM
CyberGSDude
No offense but what???
Must be that Arizona heat!
Old Jul 4, 2006 | 03:55 AM
sandramae's Avatar
sandramae
1st Gear
Default Convertible top adjustment question
My 1999 conv. top needs to be adjusted also. The driver's side window hits the top when closing the door and fraying is there. I reviewed the window tip in adjustment document and looked at the pictures however someone added a comment to the bottom of that post indicating the window adjustment is really a bar in the middle of the top that can be adjusted outward to push the top away from the window. Anyone have pictures of this adjustment? I see the bar and see a couple of screws attached to the bar but do not see how loosening these bolts will allow me to extend the bar to push the top out slightly.
My email is s-frenzke@peoplepc.com Any help is greatly appreciated since the local Chevy dealer does not want to have anything to do with this problem.
Old Jul 4, 2006 | 09:35 AM
rws.1's Avatar
rws.1
e-mail sent...
Old Jul 19, 2006 | 12:45 PM
theesportscar's Avatar
theesportscar
Can you copy me on the document?
cj_chadjohnson@hotmail.com
Thanks!
Old Jul 19, 2006 | 12:57 PM
Dixievet's Avatar
Dixievet
CI 7, 9, 10 & 11 Veteran
St. Jude Donor '08-'09-'10
I believe in the Beer Fairy
I too would like to see that document.
mtjulietdba AT yahoo DOT com
Old Jul 19, 2006 | 04:30 PM
dougbfresh's Avatar
dougbfresh
I made the adjustment to my 01 to keep it from rubbing the cover and I got the static shield to put on just in case.
Old Jul 19, 2006 | 05:05 PM
RPOZ4Z's Avatar
RPOZ4Z
the adjustment is just a "band aid" fix, you need the new updated rear weatherstrip for the top if you don't want it happening again.
To Convertible top problems Need help
