key fob relearn ?
Old Apr 15, 2006 | 01:13 AM
Carbotech Adam's Avatar
Carbotech Adam
Supporting Vendor
St. Jude Donor '11,'13
Default key fob relearn ?
how do reset it and the tire pressur monitors. i know this is old bought i for got . thanks in advance.
Old Apr 15, 2006 | 01:36 AM
ALLEGRO's Avatar
ALLEGRO
Your title says KEY FOB and the text says TIRE PRESSURE.
Which is it....or both?
Old Apr 15, 2006 | 01:46 AM
Carbotech Adam
Supporting Vendor
my bad i need both sorry.
Old Apr 15, 2006 | 02:02 AM
ALLEGRO's Avatar
ALLEGRO
I know that the fob learn is in the owners manual. I just did that for my new CorvetteKey. Do a search and you can find step by step on the pressure sensors too.
Old Apr 15, 2006 | 02:10 AM
CARRJET's Avatar
CARRJET
If you have the owners manual it tells you how there. If not I will try from my memory since I am at work now. don't quote me on this. at the end of the OPTIONS menu with a blank screen on the DIC press and hold RESET, then FOB TRAINING should appear and follw directions, for tires you have to use a MAGNET at the valve stems when the TIRE TRAINING menu prompts you. Hope this helps maybe someone else can chime in good luck
Old Apr 15, 2006 | 03:28 AM
Ducati749's Avatar
Ducati749
haha what does FOB stand for.....
Old Apr 15, 2006 | 03:43 AM
ALLEGRO's Avatar
ALLEGRO
For Opening Better
Old Apr 15, 2006 | 04:30 AM
Ducati749's Avatar
Ducati749
For Opening Better
are you pulling my leg?
Old Apr 15, 2006 | 07:27 AM
topless99's Avatar
topless99
i just did my tire sensors with a 6x9 speaker magnet. Got immediate beeps at all four wheels and took all of 3 minutes.
Old Apr 15, 2006 | 08:30 AM
BobbyG's Avatar
BobbyG
St. Jude Donor '06-'07
Default Key FOB Programming
Remote Entry Key FOB Instructions
Transmitter Programming Procedure One
1. Close all vehicle doors
2. Insert key into ignition lock cylinder
3. Press and hold the door unlock switch
a. While holding the door lock switch in the unlock position, cycle the ignition ON, OFF, ON, and OFF.
4. Release the door unlock switch. The doors will lock and unlock to confirm the program mode.
Transmitter Programming Procedure Two
3. Press and hold both the LOCK button and the UNLOCK button simultaneously on one transmitter
a. After a delay of approximately 15 seconds, the doors will lock and unlock to confirm the programming of that transmitter.
4. Repeat the previous steps to program up to 4 transmitters.
• Turn the ignition switch to the RUN position in order to exit the keyless entry transmitter mode.
• Operate the transmitter functions in order to verify correct system operation.
Transmitter Programming Procedure Three
1. Turn the ignition switch on
2. Clear Driver Information Center (DIC) options until a blank screen is displayed
3. Hold the reset button until the FOB training is displayed
4. Press reset button again
5. Driver Information Center will display step by step instructions
To key fob relearn ?
