I want to replace my H-pipe
Old Apr 15, 2006 | 11:48 AM
Z06-Goose's Avatar
Z06-Goose
Default I want to replace my H-pipe
I have a bunch of questions about replacing my H-pipe for an X-pipe.
What's the diameter of the H-pipe inlets?
Will it be any change in performance by doing this?
Can you go x-pipe and still keep the cats?
What I want to get is NOT a "full" x-pipe, but just the cross section area as shown in the picture below. In order for me to order it, I need to know what diameter to order the dual inlets: 2.25" 2.5" or 3" to fit my stock exhaust system on my 02 Z06 (which one I want?)
I plan on ordering the LG Street Headers that can be purchased without the x-pipe for $695. The X-pipe below is only $85.00 if I go 3" but I don't know what size fits. For now, I just want the X-pipe
Thanks for your help
Goose
http://www.autoanything.com/exhausts...A2672A0A0.aspx
Old Apr 15, 2006 | 01:25 PM
chuck1026's Avatar
chuck1026
Cruise-In II Veteran
Old Apr 15, 2006 | 09:12 PM
sxeC7's Avatar
sxeC7
St. Jude Donor '06-'07-'09-'10
Your pipes aft of the catalytic convertors are 2.5" O.D. You'll want an X section that's 2.5 I.D.
Unless you have the X section welded in, you'll need some good band clamps, also.
Old Apr 15, 2006 | 11:55 PM
phils C5 vette's Avatar
phils C5 vette
St. Jude Donor '12-'13-'14
i did not think it helps much
Old Apr 16, 2006 | 12:51 AM
Z06-Goose's Avatar
Z06-Goose
Thank you very much.
I'm not really expecting a whole lot, but it should be a bit better than the stock H-pipe. I hope.
Goose
Old Apr 16, 2006 | 10:19 AM
Uncle John's Avatar
Uncle John
Goose, I'm doing the exact same thing. I'm doing it to reduce the "burble" when decelerating. Also, you should see some improvement in exhasut balancing. If you actually cut your "H" crossover in half when you remove it, you'll see that even though the outside of the pipe is 2 1/2 " the actual internal size of the crossover is only 1/2 to 3/4 " in diameter.
Old Apr 16, 2006 | 10:34 AM
C5XTASY's Avatar
C5XTASY
Goose
Too bad you're not closer to Monticello, Minnesota, I have a full center section, with a welded in X-pipe, and cats, off a 2000 C5, that would bolt right into your car, that you could have for $50. It's in perfect condition, and only 25,000 miles on it. I just need to get rid of it as I have no use for it. I have installed longtubes, w/high flow cats, etc. Shipping on these things is fairly high unfortunately, I think about $125-150, so probably cheaper for you to try to score one nearer to you.
Ed
Old Apr 16, 2006 | 10:40 PM
Rou-Rou 03's Avatar
Rou-Rou 03
If your going to put on the longtube headers I believe the x pipe that comes with the kit is 3in starting at the collector then bolts to muffler pipes at the flages
Old Apr 16, 2006 | 10:49 PM
rgtkst's Avatar
rgtkst
my local muffler shop. "mienekie" put the same one in my cpe for $120-$125 installed. weld it in there. they can hang up on things and it would suck to have it come loose and fall off. especialy going down the road and thru someones windshield.
Old Apr 16, 2006 | 10:52 PM
Crabr1's Avatar
Crabr1
Default Where???
Does it make a difference where you put the x-pipe,I have seen them before the cats and some after the cats.I'm getting ready to install the rest of my exhaust and was thinking about putting them after my stock cats,will that help at all or am I wasting money?? Does it make a diff how close or how far the x-pipe is from the headers.I do want to keep my stock cats,I don't know why yet but for now I do.
To I want to replace my H-pipe
