What's going on, pull key, wait 10 seconds
Old Apr 15, 2006 | 04:37 PM
bosshoss bill's Avatar
bosshoss bill
Default What's going on, pull key, wait 10 seconds
2 of the last 3 times I drove my 98 (Vert 27k miles) When I start it up, After putting in it reverse, I get the pull key wait 10 seconds and it cuts out. After I do what it says, it's ok.
Cleaned the key with alcohol, had the steering column lock recall\done,
took it back to the dealer after the column lock recall, naturally nothing showed up.
Installed a window valet a few months ago, all seems well with that. Don't think it's the cause of this problem.
Any ideas?
Bill
Old Apr 15, 2006 | 04:47 PM
boosted_z06's Avatar
boosted_z06
If the battery has a weak cell then it cannot handle the current load on startup and cannot handle the load for the CL relay
Old Apr 15, 2006 | 04:58 PM
Dave1998's Avatar
Dave1998
Take the battery to Advance Auto Parts and get a free load test
A weak battery will do this
Old Apr 15, 2006 | 08:25 PM
bosshoss bill
Default pull key wait 20 seconds
Thanks Guys
I'll check the battery asap!
Bill
Old Apr 16, 2006 | 09:56 AM
99 vett babycar's Avatar
99 vett babycar
Old Apr 16, 2006 | 11:46 AM
purrvert's Avatar
purrvert
With a little hindsight both times I had that warning, my column lock failed. Both times were due to the same leaky battery not holding charge. Did not find leaky battery till after second column lock incident.
To What's going on, pull key, wait 10 seconds
