ready for more power.. .need advice
Old Apr 16, 2006 | 02:50 PM
JTizzle's Avatar
JTizzle
Default ready for more power.. .need advice
well just took the car out of storage this weekend and it was so nice to be back in the vette and out of the winter beater. So after a few hours of driving i was used to the power again and ready for more. Im kinda torn between what to do next. I dont wanna spend more than 2k this summer and i dont wanna sacrifice any drivability. I was leaning towards 4:10 gears or a set of new heads. Any advice would be very appreciated, im just looking for a little direction from those who have been down this road already. Thanks in advance. here are the engine mods so far:
Dynatech Long Tube Headers and x-pipe
SLP Power-Flow Rear Section
LS6 intake manifold
CF intake duct
Comp Cams 224/581 Cam
Comp Cams Pushrods
Comp Cams Valve Springs
Samco 7-Piece Coolant Hose Kit
Hypertech 160 Degree Thermostat
ASP Underdrive Crank Pulley
Old Apr 16, 2006 | 02:53 PM
mdhmi's Avatar
mdhmi
If you have an M6 I would probably do the 4:10's and then leave it alone until you're ready to go into the motor.
Mark
Old Apr 16, 2006 | 04:42 PM
LeMansBlue04's Avatar
LeMansBlue04
Between parts and Labor changing the gears is going to eat up most of that 2K budget you mentioned. Past that, and it will be more expensive, will be a replacement of your LS6 heads with aftermarket units such as AFR.
Since you will have it apart be sure to take a close look at your clutch.
Old Apr 16, 2006 | 05:38 PM
testpros's Avatar
testpros
4.10 all the way. Awesome mod. Next to my H/C package, it was by far my best mod.
Old Apr 16, 2006 | 07:00 PM
SpeedyD's Avatar
SpeedyD
Me personally, i wouldn't do the gear. I love the top end of my car and really being able to stretch it out on some open straightaway, of course not on the street! Anyhow, I havne't been in a Vette with the 4:10 but I'm thinking that would really put a damper on the top speed of the car. Some would say you could pull it in 6th but I have heard many say that you shouldn't stress 6th like that. Just my opinion, I love the all around aspect of the Vette. If you're a quater miler than the 4:10 will be geat. Good Luck
Old Apr 16, 2006 | 07:09 PM
zeevette's Avatar
zeevette
Utter nonsense. Even @ 4.10, you won't have enough power to pull redline in 6th. And this don't "stress" 6th....don't know wtf that is.
Old Apr 16, 2006 | 07:53 PM
Team 4R's Avatar
Team 4R
Cruising
longest gear, and at high speeds (thus highest inertia)... engine has to work the hardest to make the car go.
also, a lot of cars run leaner in their final (cruising) gears for the sake of gas mileage... i dont know if the vette is set up like this though
Old Apr 16, 2006 | 11:18 PM
JTizzle's Avatar
JTizzle
so if the gears are the best bang for my buck, who makes the best setup? i have looked into the MTI's but i dont know if there are any better brands. Im assuming its better to buy the rearends with the gears already installed correct? And with 4:10s i suppose i will actually use my sixth gear other than on the interstate
Old Apr 16, 2006 | 11:25 PM
FAAASTJEDI2000's Avatar
FAAASTJEDI2000
going into 6th lowers rpm and thus the hp...and thus the top end would drop. There have been some posts on vettes shifting into 6th and slowing down.
Old Apr 17, 2006 | 10:19 AM
JTizzle's Avatar
JTizzle
so if i get 4:10s and have to shift into 6th i will lose topend power?
Old Apr 17, 2006 | 12:23 PM
LeMansBlue04
What gears are really about is leverage. The only power loss you will experience is that which we all lose to heat and friction as the torque moves through the drive train. With an M6 this is somewhere around 15%.
To me a modified C5 with more than 400 RWHP is a 200 MPH + vehicle. However, on what interstate freeway or track are you going to be running your street driven car at those kinds of speeds? We don’t have an Autobahn around here so what difference does it make? With the 4.10’s and 6th gear you can get more speed than our roads can safely handle.
Now before anyone jumps on me, yes, I know that some people are nuts and drive extremely fast on the freeway from time to time. I know of a couple of guys who hit 180 late one night. But really, isn’t that pretty foolish and do you really need to concern yourself about building a high speed street car?
I am realistic about what I am going to be doing with my car and since I do not plan to drive any high bank ovals at Daytona or Talladega I keep it real.
Old Apr 17, 2006 | 02:09 PM
JTizzle's Avatar
JTizzle
i see. Good info. So basically since i never plan on driving faster than 150MPH the 4:10s should be just fine. And would give me more driving enjoyment than a set of heads that cost less than 2K?
Old Apr 17, 2006 | 02:47 PM
FrankTank's Avatar
FrankTank
CI 7-8-9-11 Veteran
St. Jude Donor '06-'10, '13
The 410's on a 6speed is a good mod, but just remember, traction will become an issue...but some like spinning the tires all the time even with a street drag tire, you'll be smoking em pretty easy...heck I can do that with my 342's and BFG's on a stock LS1 motor
Old Apr 17, 2006 | 03:16 PM
LV Vette's Avatar
LV Vette
St. Jude Donor '08
D.T.E. without a doubt. Most of the vendors that sell new hi-perf differentials are actually selling the D.T.E. units. When and if you go that route, get the hardened driver’s side output shaft and the transmission brace. After you go through the break in period, hang on to your hat and be prepared for a case of perma-grin. You will love the 4.10’s!!!
Thanks,
Clayton from Las Vegas
Old Apr 17, 2006 | 04:22 PM
JTizzle's Avatar
JTizzle
well thanks for the info guys! i am pretty sold on the gears now so im gonna do some research to see the best place to buy them. Is there a certain place to buy them from that is better than others?
Old Apr 17, 2006 | 04:42 PM
zeevette's Avatar
zeevette
You'll still be able to exceed 150 with ease. You will run out of HP before you run out of RPMS.
Old Apr 17, 2006 | 07:49 PM
JTizzle's Avatar
JTizzle
sounds good to me...Non where is the best place to buy the 4:10s?
To ready for more power.. .need advice
