Does rim/tire width affect lowering?
Old Apr 17, 2006 | 06:44 PM
C6this's Avatar
C6this
Default Does rim/tire width affect lowering?
Yeah I have a 03 Z and I am running 18x12's on the rears with BFG t/a g-force drag radials that are 30/315/18. Will lowering my car cause me to rub since they are wider? Thanks
Old Apr 17, 2006 | 07:03 PM
NOT-MEE's Avatar
NOT-MEE
Cruise-In V Veteran
Cruise-In VI Veteran
Cruise-In VII Veteran
St. Jude Donor '06-'07
It all depends on wheel offset. I am running 18/19 combo and I have to run a 1/16 spacer to keep from rubbing inside rear wheel well during aggressive driving.
Lowing always changes the camber and caster the wheel placement.
I recommend doing a alignment after lowering.
Old Apr 18, 2006 | 12:09 AM
JETZ's Avatar
JETZ
Your wheels are already sticking out passed the lip. right?
Lower your car, hit a pothole etc., tire hits lip, and fractures the fender, end of story!
Sounds like a tub, and proper fitting wheels are in order.
Old Apr 18, 2006 | 02:58 PM
C6this's Avatar
C6this
I understand what you are saying about hitting a pothole but lowering on stock bolts is not going to put me that close to my tires I just would like to know if its going to rub?
Old Apr 19, 2006 | 08:05 PM
JETZ's Avatar
JETZ
Most guys with a 305/315 run an 11'' wheel not a 12. Having said that, because of your wider wheel, you might still have to remove the brake ducts.
Old Apr 20, 2006 | 12:28 AM
MrLeadFoot's Avatar
MrLeadFoot
I just helped someone lower their car on stock bolts with 12's on the rear, and although his tires did stick out a hair, we didn't notice any problems. But, this was only a few days ago, so I don't know if it will settle that much more to cause an issue.
HTH
To Does rim/tire width affect lowering?
