Passenger window misbehaving
Old Apr 18, 2006 | 02:00 PM
cruisemon's Avatar
cruisemon
Default Passenger window misbehaving
Found the thread on this problem, tried the door slam, didn't work. I think I may as well resign myself to replacing the motor/track assembly. Would it be a good idea to check codes before I do that? I don't have my service manual yet and so far it looks like I'm looking for a B2275 motor or B2208/B2206 switch fault. I can hear a relay or something clicking when I push either of the window controls for the passenger side.
If I do have to replace the motortrack assembly, can someone recommend a dealer who will discount the assembly? I found one over in North Carolina (maybe Winston Salem?) for some C4 parts but cannot remember the name to save me.
Charlie
Old Apr 18, 2006 | 02:12 PM
sxeC7's Avatar
sxeC7
St. Jude Donor '06-'07-'09-'10
Well make it stand in the corner if it's being bad.
Seriously, check the Forum Supporting Vendors on the left. Fred Bean and GM Parts Direct are to good sources for parts.
Old Apr 18, 2006 | 02:26 PM
cruisemon's Avatar
cruisemon
Default Well make it stand in the corner if it's being bad.
I have found that sometimes beating it like a rented mule helps. May not be the case this time. The suggestion about forum vendors is so good and so obvious. :o
Thanks for the tips!
Charlie
Old Apr 18, 2006 | 04:27 PM
95jersey's Avatar
95jersey
This is a common problem with C5's.
To Passenger window misbehaving
