90MM FAST Intake or not...???
Old Apr 18, 2006 | 06:51 PM
01QSZ06's Avatar
01QSZ06
Default 90MM FAST Intake or not...???
Should I or shouldn't I? I can't decide. My Z is going in for some AFR 205's and a mild cam in two weeks and I can't decide if I should spring for the FAST or not. Who's done it and who hasn't?? Wish you would have, happy you did, or glad you didn't?? I know it's only going to be worth 15rwhp or so... and it's a very subjective decision, but your opinions would be much appreciated! Anyone do H/C and later put on the FAST? MPG loss?
THANKS
Old Apr 18, 2006 | 07:15 PM
killaz's Avatar
killaz
Old Apr 18, 2006 | 07:21 PM
John Shiels's Avatar
John Shiels
From: Buy USA products! Check the label! Employ Americans
mild cam and stock cubes will probably not gain that much.
Old Apr 18, 2006 | 07:38 PM
99 C-5 F1C VETTE's Avatar
99 C-5 F1C VETTE
dont really think its worth the money for the little gain, i have a LS-6 intake on my 382 f1-R 812 rwhp @14psi
Old Apr 18, 2006 | 07:40 PM
mdhmi's Avatar
mdhmi
Probably 10-15 hp difference with that combo and a FAST 90 manifold and TB. That's a pretty bad bang for the buck ratio if you ask me.
Mark
Old Apr 18, 2006 | 08:59 PM
phils C5 vette's Avatar
phils C5 vette
St. Jude Donor '12-'13-'14
ttt
Old Apr 18, 2006 | 10:05 PM
Vette45's Avatar
Vette45
A&A is putting my Fast 90 and LS2 90 TB on tomorrow. I 'll let you know the results!
Old Apr 18, 2006 | 10:10 PM
Face's Avatar
Face
If you're using a good tuner you'll see some gains.
Old Apr 18, 2006 | 10:26 PM
gojo's Avatar
gojo
THANKS
http://forums.corvetteforum.com/show....php?t=1363284
Sounds like your question.
Also, since your intake is coming off the labor should be minimal. Suspect the "bang for buck" will be pretty good. How does it compare to headers?
Old Apr 18, 2006 | 10:43 PM
Bink's Avatar
Bink
Cruise-In V Veteran
St. Jude Donor '09
THANKS
I did H/C and then later added the Fast 90mm and a Nick Williams TB. I previously had an LPE ported TB and stock LS6 (port matched) intake.
I was tickled to death with the part throttle drivability and responsiveness. Sure, topend was stronger....but I don't stand on it that often. It was worth it for part throttle improvements.
South Tex Vette's Avatar
South Tex Vette
I gained 26 rwhp adding the Fast 90 Intake along with the 90 mm TB, but what unleashed it on the dyno was removing the MAF with a speed density tune. If you every plan to use N20 buy the burst panel option (cheap insurance)
Old Apr 19, 2006 | 08:04 AM
2000whitec5's Avatar
2000whitec5
From: 10.54 @ 129 346 N/A A4 Record 9.78 @ 139+ on 150 shot
http://forums.corvetteforum.com/show....php?t=1363284 my results .. IMO was well worth it
Old Apr 19, 2006 | 11:24 AM
HRDTOPC54FUN's Avatar
HRDTOPC54FUN
I was also considering the LSX/NW 90 this winter but backed off on it. At the time I couldn't find any definite data on the potential gains (h/c package W/ LTs and CAI).
Instead I went with a Callaway large bore billet TB and a high flow MTI Racing composite MAFS. I am expecting about 10 rwp and 14 rwt increase with this set-up, plan to dyno in a few weeks, feels stronger especially in the mid rpm range.
Since then I have seen several before/after dyno runs (figures) on the LSX 90 I now think I left at least 5-8 rwhp and 5-6 rwt on the table by not going with the fast 90.
If I was do to it agaim I would definetly go woth the Fast 90. Also, be aware that NW is no longer producing the 90 mm TP for the C5. You may want to contact them right away if you are interested in the NW90
Just my 02. Hope this helps.
Old Apr 19, 2006 | 12:01 PM
grinder11's Avatar
grinder11
THANKS
I have the 90mm FAST and the 90mm LS2 TB. I also have a large cube motor, and after spending the big bucks, I felt it was really more of a no brainer than your situation is. I mean, after dropping over 10 grand, whats another grand? So I got one. From what I have seen, there is very little loss at lower revs as far as torque goes (M.P.G.). And seeing as how the AFR 205's are actually more efficient than the factory head, at both low and high revs, whatever small amount of low speed torque lost with the FAST would be more than an even swap when the 205's are factored in. If you can, check out the LS1/LS6 book by Will Handzel, as mentioned in these posts. They have a direct comparo with the LS6 intake when running a small (.580 lift, 210 dur. @ .050 lift on intake, 216 dur. @ .050 lift exh. ) cam and picked up about 10 horses. With your set-up, you may see even more, like 15+ horses, and after all the bucks you have spent, or will spend, I would think you would go for it, but thats just my .02. On the other hand, there may be another new intake just over the horizon that will be at SEMA later this year and be even better..... who knows.
To 90MM FAST Intake or not...???
