Diff. swap
Old Apr 19, 2006 | 01:33 PM
almondted's Avatar
almondted
St. Jude Donor '07-'08
Default Diff. swap
Does the tranny have to come down with a differential swap?
Any how to swap rear-end or web site with step by step info would really help... Had a used diff. put in but it has a whine in it so I now have a new one ready to go in and am thinking of doing the swap myself. Thanks... Oh yah, It's an automatic!
Old Apr 19, 2006 | 02:26 PM
htvette's Avatar
htvette
I have done a diff swap for a manual trans and the trans and diff have to be lowered together for the diff to clear the tub. Then separate the diff from the trans.
Old Apr 19, 2006 | 02:40 PM
94legaleagle's Avatar
94legaleagle
I did my auto this winter - the tranny has to be lowered in order to slide the differential off of the transmission output shaft - check Cajundude's website - he has an EXCELLENT write up, w/ pictures and torque specs, for a step by step removal and install of a rear differential - print Cajundude's write up, take it to your shop/garage, and you can do it yourself.
Mike Mercury also has a good write up on the subject.
Do a search also, you likely will find links to these writeups and other useful information.
Old Apr 19, 2006 | 04:44 PM
DJMRTS's Avatar
DJMRTS
if you get a diff. from a six speed vette, you must use the cover plate from your automatic diff and place it into the diff. from the six speed.
To Diff. swap
