Help with AC problem
Old Apr 19, 2006 | 09:58 PM
99HRDTP's Avatar
99HRDTP
Default Help with AC problem
I have the automatic dual zone unit, and no matter how low I set it, there is no power output of the vents. I have recharged the freon, with no change. I can hear the fan get louder, but the cold air doesn't blow out any harder. Any ideas?
Old Apr 20, 2006 | 01:11 AM
my6thvette's Avatar
my6thvette
Sounds like a typical vacuum leak problem. Usually caused by leaking battery acid which damages nylon vacuum lines located below or behind the battery. Check the battery for leaks.
Old Apr 20, 2006 | 01:50 AM
ecudooberhead's Avatar
ecudooberhead
There is a vacuum line that runs to the back of the intake- make sure you check it out, it can come out quite easily
Old Apr 20, 2006 | 07:03 AM
99HRDTP's Avatar
99HRDTP
Thanks, guys.
The battery did have an issue several years ago with a leak that damaged something to do with the HVAC system, however, this was replaced and the Optima Redtop that I have has never had problems.
I will check on the vacuum line.
Mike
Old Apr 20, 2006 | 08:34 PM
99HRDTP's Avatar
99HRDTP
Can you give me any more specifics on the location? Thanks.
Mike
To Help with AC problem
