TPS adjustment
Old Apr 20, 2006 | 10:01 PM
SLPRC5's Avatar
SLPRC5
Default TPS adjustment
Can someone explain to me how to reset the tire pressure sensors..
Thanks,
Rsty
Old Apr 21, 2006 | 02:37 AM
atz06's Avatar
atz06
Sensor Learning Procedure:
With the wheels mounted and the car on the ground:
Turn ignition to ON position.
Press the DIC RESET button to clear any warning messages.
Press the DIC OPTIONS button until the display goes blank.
Press and hold the DIC RESET button for 3 seconds.
Press the DIC OPTIONS button again until the "TIRE TRAINING" message appears.
Press the DIC RESET button until the message, "LEARN L FRONT TIRE" appears.
Hold the magnet(s) over the pressure sensor’s location on the LEFT FRONT wheel (this should be next to the valve stem sides if installed correctly).
When the horn honks, programming is complete for that wheel.
Program the other 3 wheel sensors as directed by the message display. The sequence is as follows: Left Front, Right Front, Right Rear, Left Rear.
