TNT vs NX nitrous kits
).Thanks!!
Jerry
[Modified by Skeeter1, 5:38 PM 8/20/2001]
Jerry
[Modified by 99 Corvette, 4:45 PM 8/20/2001]
NX is also rated at rear wheels.
Some manufactures resort to marketing to promote there kits. If a kit is rated at 100 RWHP and kit produces 120 RWHP, its called marketing. Fact is to gain the extra 20RWHP the kit uses more Nitrous than the company who has rated there kit at a legit 100RWHP.
I would avoid kits that mount solenoids right in the middle of your engine heat. Solenoid failure is your major concern with N20 Kits.
[Modified by jetskifast, 5:52 PM 8/20/2001]
Skeeter1 I agree with you. I don't know where they got that Nx solenoids are better. If you mounted them where the TNT solenoids are you would probably have problems. It seems to me in the last 2or 3 wks I have read more post about Nx solenoids sticking open because they can't take the heat from holding them open long enough to win a race.
bb Call Jason at MTI or Nick at ARE and ask them what they think about TNT nitrous kits. Call Nx and ask them what the air/fuel ratio is on the spray and call TNT and ask them. Then decide which one your engine will live the longest with.
"TNT ROCKS"
"RUN ONE OR FOLLOW ONE"
p.s. I LOVE Nx kits.
Dont think you can go wrong with either tnt or nx
Who makes TNT solenoids? TNT, NX and NOS may be all purchasing solenoids from same manufacture.
Solenoid seals are what fail over time from heat. For a street car under constant heat, why would you mount solenoids in the heat? And risk solenoid seal failure?
Instead of being a TNT salesman, you should not misinform forum members about the dangers of heat with N20 solenoids. Solenoid failure is the major reason for blown motors using N20.
Also please post how one manufacture of nitrous kits. Using same amount of nitrous sprayed, at same pressure before throttle body, can out perform another? More nitrous=more HP period. All name brand Nitrous kits will perform the same, under same conditions and setup.
142 bottles in less than two years, over three per week? You have been posting 142 bottles used for some time here and on http://www.ls1.com have you stopped using your Nitrous?
[Modified by jetskifast, 8:31 PM 8/20/2001]
Joe
Could you explain how TNT amorized N20/Fuel better than other kits? I have heard this from other TNT owners, but none could explain how it is done.
Wet kits have fuel and N20 jets pointed right at throttle body opening. Once fuel and N20 hit throttle body it does not matter how it got there, you have intake manifold to mix things up. All that matters is how much N20 is there. More N20=More HP.
99Hardtop
Reread my posts. I have never said not to use TNT kits or have I pushed any brand of N20 kits. Common sense tells you over the long run you may run into heat problems with solenoids mounted in hot spots. By the way I know of a few people who have had heat failure.
[Modified by jetskifast, 10:48 PM 8/20/2001]
All the responses bring up a couple more questions:
1. If Solenoid failure is the greatest risk with most nitrous setups, what is the solution to keep the heat off of them? Is it to do what hrdtopv8 did and heat wrap them, is it to strategically mount them in a cool area, some combination of both, etc.?? Or, is it enough to simply make sure you nitrous filter is kept nice and clean??
2. Just out of curiousity - which system do the big boys like SW use?
Thanks again!
Jetskifast do you remember the post not long ago where I ask you to get NOS,Nx,Nitrous Works,TNT nozzles put the same jets the same pressure and see the diffferance in the spray? I guess not because you still say it does not make any differance as long as it is sprayed before the TB. "WRONG" NOS,Nx and other manufactures said "QUOTE" " You can not put a wet nitrous kit on a LS1 because the fuel will puddle in the LS1 intake and blow your engine up." TNT came out with the wet kit for the LS1 and now everyone has a wet kit. You say it does not matter how you get the nitrous and fuel to the TB and the intake mixes the together. I guess you can take a fuel line and nitrous line and put them together with jets, and you don't need a nozzle to make a spray pattern. You can shot a stream of nitrous and fuel out of the jets straight through the TB and it will work ok. Explain that one. All this time the nitrous companies have been wasting thier time making nozzles with spray Patterns to help adamize the fuel and nitrous in the engines. WOW thats news to me.
I had my system installed, finally. I went to MMS. I just didn't have the time or the patience to do it myself. But thank you for all the help you had given me.
The "TWIN" Gemini system is awsome, lots of gas injected into the system. You can see by the images, there are 2 ports, not one.
This produces a well balanced shot, at least in my view. Also, the "Maximizer" is a good investment. The delayed introduction of NOS, starts at 40% and goes to 100% in 4 seconds (defalt values) is really great for racing, minimum wheel spin, and a safer ride. I feel the ET's will be better as well, although I need to get to the drag strip to test it.
I really like the results. :D It is extremly fast as I am sure you are well aware. :smash:
Thanks again for you assitance! :yesnod:
Bruce1
Check the Dyno...with and without the NOS....!
Oh Yea........
2 (double) twin gemini ports
Look familiar???The Hook up is just like yours!
Thanks!!!!!!!!!!! :cheers:
[Modified by bruce1, 11:09 PM 8/20/2001]
[Modified by bruce1, 11:10 PM 8/20/2001]
