Radio locked ??? Need help.. 6 digit code????
Old Apr 21, 2006 | 02:28 PM
RichAshley-Black99's Avatar
RichAshley-Black99
Default Radio locked ??? Need help.. 6 digit code????
Ive been gone and my wife hadnt started the vette I had to get a new battery........ any how I searched through the post here to find out how to unlock it "the radio"......, and went through the procedure well when I called the number to get the code it gave me a 6 digit code not a four. I cant even enter the code because the start of the number is to high a number and it will only take a four digit code ???????????????
Old Apr 21, 2006 | 03:53 PM
rwlc5's Avatar
rwlc5
The following procedure will give you a new code that you can use instead of your personal code. Using this new code, you can “unlock” your radio and then “re-lock” it with a new code if you wish.
Prerequisites:
The radio must be in LOC mode NOT in INOP mode.
Let me explain. If you have activated the Theft-Deterrent feature of your radio and loose power, the radio goes into LOC (theftlock) mode. With the ignition on, you must use the MN and HR buttons to enter you personal code in order to unlock it (The instructions are on page 3-27 in your Y2K Owner’s manual). If you fail to enter the correct code eight (8) times, the radio goes into INOP mode. You have to wait an hour with the ignition on before the radio returns to LOC mode (go for a long drive somewhere).
Procedure:
01. Turn the ignition ON (The radio displays LOC)
02. Hold down the Radio Presets 2 and 3 buttons for six seconds
03. The radio display changes from LOC to a three-digit number. Write this number down. Don’t take forever, fifteen seconds max before the next step.
04. Press the AM/FM button
05. The radio display changes to another three-digit number. Write this number to the right of the first one.
06. You now have a six-digit number, the first three digits are from STEP 03 and the last three digits are form STEP 05
07. Call 1 800 537 5140
08. Press 1 then # (pound). You’ll hear “Invalid Code, try again”
09. Press 139010 then # (pound). You will be asked to enter your four or six digit code followed by * (star)
10. Enter the number from STEP 6 then * (star)
11. Listen to the four-digit number and write it down. It will be repeated twice
12. Turn the ignition ON (The radio displays LOC)
13. Use the MN and HR buttons to enter the code from STEP 11
14. Press the AM/FM button. The radio display changes to SEC
Your radio is now “un-locked” and usable. The Theft-Deterrent feature is STILL active! If you want to disable it, use the instruction on page 3-27 in your Y2K Owner’s manual. Use the code from STEP 11 instead of your personal code.
Note: This tip originated from LOTZAHP, Austin TX (credit must be given where credit is due).
I think I got this form the forum a year or so ago and saved it for future refernece just in case. i hope it helps you
Old Apr 21, 2006 | 03:56 PM
rws.1's Avatar
rws.1
is this the procedure???
IT suggests that when you call the number they will give you a 4 digit code to use....
down. Don't take forever, fifteen seconds max before the next step.
08. Press 1 then # (pound). You'll hear "Invalid Code, try again"
09. Press 139010 then # (pound). You will be asked to enter your four or six digit code followed by * (start)
Your radio is now "un-locked" and usable. The Theft-Deterrent feature is
your Y2K Owner's manual. Use the code from STEP 11 instead of your personal
code.
Looks like others save posts for future reference.....
Old Apr 23, 2006 | 01:08 PM
RichAshley-Black99
code.
I did all the above but when I called the number and went through the process instead of a four digit they gave me a 6 digit code when I called...... theres no way to even enter it . they cited 644891 to unlock it????? I dont know
To Radio locked ??? Need help.. 6 digit code????
