lifting the backend for exhaust installation
Old Apr 21, 2006 | 02:32 PM
pmorcos's Avatar
pmorcos
Cruising
Default lifting the backend for exhaust installation
Is there a "good best" way I can lift just the backend the few inches needed to replace my cat-back exhaust?
I don't have a lift and I want to do it myself!
Old Apr 21, 2006 | 02:41 PM
rws.1's Avatar
rws.1
you can do it yourself... but be prepared to get the bottom of the rear fascia 28-30 inches off the ground.
That usually means putting the front wheels on ramps or a 4x4 and putting a sandwhich of a 4x4 bwtween 2- 2x6's ( 8 extra inches of lift) as a pad on top of your jack to get enough height....
It is high and not for the inexperieinced or faint of heart !!!
Old Apr 21, 2006 | 02:43 PM
pmorcos's Avatar
pmorcos
Cruising
Default Lol
I like to stay behind the wheel...above the wheels...but never under the wheels. I guess that would mean I'm "faint of heart".
I'm thinking I'll have it installed.
Old Apr 21, 2006 | 03:33 PM
REDFIRE's Avatar
REDFIRE
Tuffy Muffler removed my stock system including the "H" pipe and installed my new Magnaflow system including the "X" pipe for $80.00. They were very accomodating and careful not to scratch anything. Very pleased and well worth it.
Old Apr 21, 2006 | 03:38 PM
OhioDave's Avatar
OhioDave
St. Jude 15 Year Donor
St. Jude Donor '06-'07-'08-'09-'10-'11-'12-'13-'14-'15-'16'17-'18-'19-'20-21
If you don't have the equipment or the experience don't try this at home. The car will be unstable without the proper lifting equipment.
$80.00 is cheap to be safe
Old Apr 22, 2006 | 10:10 AM
bb609's Avatar
bb609
http://forums.corvetteforum.com/show...1&forum_id=103
Old Apr 22, 2006 | 10:52 AM
Wicked Weasel's Avatar
Wicked Weasel
St. Jude Donor '05-'08
it is really high. I did one side and needed to go higher on the other side. At that point I thought this is stupid. Lowered it back on the ramps and cut the other side...
Old Apr 22, 2006 | 12:13 PM
pmorcos's Avatar
pmorcos
Cruising
Default Good advice all....
I took the advice and looked for Tuffy...but not in my area.
I found a local muffler shop that will do it for $100.
Old Apr 22, 2006 | 06:22 PM
Rou-Rou 03's Avatar
Rou-Rou 03
you only have to be 32 in if your going to save the old exhaust
To lifting the backend for exhaust installation
