Spring has come and my baby is out. I had a new TPS installed and (maybe coincidently) my passenger door does not unlock with either of the key fob or the drivers auto lock/unlock button. No codes thrown - just won't work?
The door control module probably has pitted relays. This is a common problem. My car does the same thing, but it throws codes. You might try pushing the unlock button repeaetdly. Can you hear the relays engaging? If so try pulling the codes again. If not you may have a loose connector somewhere.
