AC is being weird
Old Apr 21, 2006 | 09:16 PM
sweetvet's Avatar
sweetvet
Default AC is being weird
I fixed my AC today by replacing the fuse, and it worked fine to begin with after intially checking it- but when I tried it again later, the driver side was blowing icecold air, while the passenger side was hot. My car has the electronic dual climate control, if that matters. Any suggestions as to what this could be?
Old Apr 22, 2006 | 01:06 AM
CARRJET's Avatar
CARRJET
Do a search from this forum. Type in B0361 or HVAC will get you in the right direction, also check and see if you hav any codes, good luck
Old Apr 22, 2006 | 03:54 PM
sweetvet's Avatar
sweetvet
Thanks bud- I did a search for "AC" but couldnt find the thread I needed- appreciate the point in the right direction
Old Apr 24, 2006 | 12:57 PM
corvette Mark's Avatar
corvette Mark
Originally Posted by sweetvet
I fixed my AC today by replacing the fuse, and it worked fine to begin with after intially checking it- but when I tried it again later, the driver side was blowing hot air, while the passenger side was hot. My car has the electronic dual climate control, if that matters. Any suggestions as to what this could be?
Low freon.
Old May 1, 2006 | 02:17 PM
sweetvet's Avatar
sweetvet
hah, whoops, meant to say that the passenger side was cold while the driver side was hot.
Old May 1, 2006 | 02:32 PM
white90conv's Avatar
white90conv
That is the symptom of low refrigerant - hot on drivers side, cool on passenger side.
Old May 12, 2006 | 09:30 AM
cloneman315's Avatar
cloneman315
low freon will make one side cold and the other hot?
To AC is being weird
