Need radiator hoses and clamps
Old Apr 22, 2006 | 11:50 AM
Snuckley's Avatar
Snuckley
Default Need radiator hoses and clamps
Had to send out my Be-cool radiator due to a tiny leak. While it's out I'll replace the hoses. Do they make those green lined HD hoses for the C5? I need the upper and lower and the 2 little lines. I think the leak was to bottoming out on either an off track excursion or trailer loading that pushed the radiator slightly upwards into the shroud causing some rubbing. Otherwise the big radiator has performed fine along with the outboard oil cooler, next time I'd probably spring for the DRM combo unit so it warms up the oil quicker here in the North.
