Hal shocks anyone using them?
Old Apr 22, 2006 | 05:48 PM
tcal95z's Avatar
tcal95z
Default Hal shocks anyone using them?
I used these on another car and they worked pretty well except for the fronts wanting to leak.
Anyone using them for the drag strip?
Old Apr 22, 2006 | 06:24 PM
Face's Avatar
Face
I installed them for the strip and they cured my wheelhop problem.
Old Apr 30, 2006 | 07:07 PM
tcal95z's Avatar
tcal95z
was that all four and what kind of tires are you using?
Old Apr 30, 2006 | 09:51 PM
Face's Avatar
Face
I installed all 4 and have used 26x11.5 E.T. streets and 28x10 Hoosiers.
Old Apr 30, 2006 | 09:54 PM
Phil97SVT's Avatar
Phil97SVT
I made a custom set of coilovers with QA1s and work like a champ.
Old May 1, 2006 | 01:05 AM
tcal95z's Avatar
tcal95z
Thanks Guys
Face,
I'm just curious had you tried anything else to stop the wheel hop before the Hals and what settings do you run them at?
I just got a CCW drag set up and I'm trying to get the other stuff figured out.
Tom
Old May 1, 2006 | 12:20 PM
Face's Avatar
Face
At first I thought my 26x10.5 E.T. streets weren't grabbing enough and causing the wheelhop. Then I went to the 28x10 Hoosiers and I still had the same problem. Then I installed the QA1's and it went away. IIRC, I ran 2 up front and 8 in the rear last time out.
Old May 1, 2006 | 12:30 PM
tcal95z's Avatar
tcal95z
Thanks Face,
Have you replaced your rear or output shafts yet?
Old May 1, 2006 | 09:54 PM
Face's Avatar
Face
Only the long side since I have a A4. If I had a MN6/12 I would have done both.
Old May 1, 2006 | 10:39 PM
REDGAR's Avatar
REDGAR
Cruise-In II & IV Veteran
CI VI Drag Champ!
Another QA1 user here. No wheel hop problems. I run 2 front, 6-9 rear depending on the track
Old May 2, 2006 | 05:01 PM
tcal95z's Avatar
tcal95z
Thanks guys. I need all the help I can get I've only had my Z06 two months
To Hal shocks anyone using them?
