Rear bearing removal - problem
Old Apr 22, 2006 | 10:02 PM
TQ's Avatar
TQ
Default Rear bearing removal - problem
So I'm to the point that I need to remove the CV axle assembly from the upright.
The splined shaft will not come out. . .
the CV is a bit rusty on the backside. . .
I've prepped it with WD40 from the front and the back. . .
and a rubber mallet isn't getting it done.
How hard can I hit it and what should I hit it with?
Dennis
Old Apr 22, 2006 | 11:03 PM
SteveDoten's Avatar
SteveDoten
Cruise-In VII Veteran
there is a press made for this specific problem, you can get it at most parts stores, or soak w/ pb blaster, put the axle nut back on and block of wood placed on top of nut, give the axle a hit w/ a ball peen
i've done dozens of bearings, never needed the press
Old Apr 23, 2006 | 04:32 AM
LS9's Avatar
LS9
Old Apr 23, 2006 | 06:30 PM
GAS's Avatar
GAS
Does anyone have the specific instructions I can download ? THANKS
Old Apr 23, 2006 | 08:39 PM
schpenxel's Avatar
schpenxel
St. Jude Donor '15
he just told you how to do it, what more do you need??
Old Apr 24, 2006 | 08:40 AM
GAS's Avatar
GAS
THE INSTRUCTIONS FOR THE WHOLE BEARING REMOVAL PROCESS WOULD BE NICE . THANKS AGAIN
Old Apr 24, 2006 | 11:10 AM
macmuta's Avatar
macmuta
Cruising
Try this link, it worked for me. Good luck
http://www.jakelatham.com/c5/misc
Old Apr 24, 2006 | 05:41 PM
GAS's Avatar
GAS
THANKS!! I tried to download that Sunday but couldn't get at it. Worked great today
To Rear bearing removal - problem
