Front Brakes on the Back
Old Apr 25, 2006 | 10:57 AM
mzr3yt's Avatar
mzr3yt
Default Front Brakes on the Back
How hard would it be to but the front calipers and rotors from a C5 on to the back of a C5? Is a kit avaialble? Also, would this mess up the brake bias?
Old Apr 25, 2006 | 04:49 PM
tropik24's Avatar
tropik24
Navigator
Don't know if it could be done but you would definitaly lose your emergency brake
Old Apr 25, 2006 | 08:31 PM
Skunkworks's Avatar
Skunkworks
Not easily and you’d do better with aftermarket kit.
Old Apr 25, 2006 | 10:27 PM
John Shiels's Avatar
John Shiels
From: Buy USA products! Check the label! Employ Americans
front right brakes to rear left. Yes it will give you a soft pedal as the piston size is larger. More bias to rear. I would not open that can of worms. Plus no ebrake may be no inspection either. Get some Wilwoods form LGM
Old Apr 25, 2006 | 10:30 PM
Ikester's Avatar
Ikester
CI 6-7-8-9 Veteran
St. Jude Donor '08-'09
To Front Brakes on the Back
