Spark Plugs
Old Apr 25, 2006 | 03:46 PM
SLPRC5's Avatar
SLPRC5
Default Spark Plugs
I posted this question in S&T section also.
Are the AC/Delco Iridium Professional spark plugs better than the NGK TR6 spark plugs for daily driving?
Thanks,
Rsty
Old Apr 25, 2006 | 03:58 PM
willyfastz's Avatar
willyfastz
From what I've seen the Iridium plugs are more for extended use. The Tr55's would probably be the better plug unless you need a colder plug then then the Tr6 would be you plug.
Old Apr 25, 2006 | 07:47 PM
C5SteveMR's Avatar
C5SteveMR
I found the new stock AC Pre gaped @40 plugs from the dealer work best. Do not attemt to gap the irridium plugs. Good luck
Old Apr 25, 2006 | 08:00 PM
SLPRC5's Avatar
SLPRC5
Thanks..
Old Apr 25, 2006 | 11:07 PM
mvvette97's Avatar
mvvette97
St. Jude Donor '06-'07-'08-'09
Hey DenoT, is your PM working yet because mine isn't.
Old Apr 26, 2006 | 12:30 AM
SLPRC5's Avatar
SLPRC5
Nope not yet Marc....only from this area..
Old Apr 26, 2006 | 04:50 PM
SLPRC5's Avatar
SLPRC5
ttt
Old Apr 26, 2006 | 05:24 PM
mph1972's Avatar
mph1972
Cruise-In VIII Veteran
St. Jude Donor '07
The NGK TR6s are typically the plug you want when you are running some sort of FORCED INDUCTION setup (ie Nitrous, SC, etc), the NGK 55s are a nice plug, but I have seen and have had problems with the tips backing out, they are a screw on tip. I am not a fan of that at all.
I went back to the ACDELCO Irdiums and appreciate the plug alot more, because I don't have to worry so much about checking the plug tips over and over again. Plus, they are pregapped by the manufacture and "ARE NOT" to be adjusted. I think they are a great plug for Daily Driving and that is what I use in my car and I drive it every day.
Micah
Old Apr 26, 2006 | 08:45 PM
SLPRC5's Avatar
SLPRC5
Micah
Thank you, I'm having the Irdium put back in Friday...I know they are pre-gapped and no adjustment needed. They are good for 100K. The installer said he didn't like to leave plugs in pass 30K, becuase he has seen where the plugs left in that long will pull the threads out of the spark plug hole...hmmmm anti-seize I think would cure that problem...
Old Apr 26, 2006 | 09:30 PM
edensknight's Avatar
edensknight
Micah
Old Apr 26, 2006 | 10:06 PM
bowtiebubba's Avatar
bowtiebubba
Micah
I just put the AC Delco professional iridium plugs in my car. The box says to set gap per vehicle specification and mine called for 60 thousands,so thats what i gapped them at. Is this wrong?
Old Apr 26, 2006 | 10:15 PM
SLPRC5's Avatar
SLPRC5
Yes, they come pre-gapped at .040 and should be left at this gap. I don't know how your performance will be with a .060. Another reason not to gap the iridium plugs is because the tips are very ez to ruine.
Old Apr 27, 2006 | 03:57 PM
bowtiebubba
I guess im not understanding this. If the manual says to gap at 60, and the plug box says to set gap per vehicle specification ,why do you leave the new plugs gapped at 40?
Old Apr 27, 2006 | 07:56 PM
C5XTASY's Avatar
C5XTASY
This is true. However, I would check the gap on each plug as you buy them at the dealer/store before you accept them, to ensure the .040 gapping was properly set at the factory.
Ed
Old Apr 28, 2006 | 11:00 PM
SLPRC5's Avatar
SLPRC5
Ha Ha..well today I had a set of Iridium plug put in to replace the NGK TR6 plugs. Let me tell you; the guy that installed them told me right off the bat he saw what I meant by an improvement with the Iridium plugs, he could feel the response. Let me say when I jumped on the freeway or even before I got there I could feel a rapid improvement.
I want to thank all of you for your input..
Rsty
Old Apr 28, 2006 | 11:39 PM
willyfastz's Avatar
willyfastz
As long as his coil packs are up to it his performance is probably better. With the wider gap it takes a hoter spark to fill the gap, which means it will burn more of the gas in the CC. Hence the reason his manual reccomends .060. Most of the GM vehicles call for a wide gap.
Old Apr 28, 2006 | 11:47 PM
SLPRC5's Avatar
SLPRC5
This is the new standards in the industry to replace the plugs in C5s with the pre-gapped .040 AC/Delco Iridium Professional Plugs. Reports are they work very well.
To Spark Plugs
Old Apr 28, 2006 | 11:54 PM
willyfastz's Avatar
willyfastz
No dought .040 is fine. I normally only run the tighter gaps on FI cars.
Old Apr 29, 2006 | 12:02 AM
rgtkst's Avatar
rgtkst
when i pulled mine out to install headers. they had a HUGE gap. like 80 or so. i tapped them, down to 60. did i mess up?? how do i know what plug they are. they have the littlest tip i have ever seen on a plug. the color was a light brown/ white. the tip was like big around as a sharp pencil. are these way worn out or is that normal?
Old Apr 29, 2006 | 12:39 AM
Darkness's Avatar
Darkness
No they're fine they come with the tip like that. And by the color you mentioned it means its running good. Now that gap was pretty big surprised it even sparked but 45-55 is what it should be and 35-40 for FI.
