G.M Target replacement engine
Old Aug 21, 2001 | 05:33 PM
teacherjim's Avatar
teacherjim
Default G.M Target replacement engine
My 1994 had a replacement Chevy Target engine dropped in under warrenty in December of 1995. Chevy took the original engine back to it's Warren testing lab to see what happened. I know it was a complete engine replacement but Iwas wondering if the new engine would have come with the water pump and a new optispark on it? The 1995 engine number on the repair sheet called for a 12523000 engine. If any of you work in a Chevy dealership and can look up this number and can let me know if the above items came on this engine I'd appreaciate it :lol:
Old Aug 21, 2001 | 05:58 PM
CP's Avatar
CP
Default Re: G.M Target replacement engine (teacherjim)
Why's it taken 6 years to ask???? :confused:
Old Aug 21, 2001 | 06:41 PM
teacherjim's Avatar
teacherjim
Because I just bought the car, a few months ago anf found all the old paper work showing what had been done. Note: I notice that I posted this in the wrong section, but. If you know the answer you could still answer) Thanks.
Old Aug 21, 2001 | 06:42 PM
Flintstone's Avatar
Flintstone
Not sure this helps, but when my '99 engine was replaced, it came as a complete long block, including manifolds, spark plugs, clutch, water pump, intake, TB, and so on...
It was plug-n-play with the exception of the harness, power steering and air conditioning.
F
To G.M Target replacement engine
