Need Help With Window
Old Apr 27, 2006 | 03:59 PM
greg 6746's Avatar
greg 6746
Default Need Help With Window
i have a problem with my drivers side window on a 98 coupe. when i roll it down it goes down to far and seems to be hitting on something is there a fix or do i need to buy a new regulator .thanks greg
Old Apr 27, 2006 | 11:22 PM
greg 6746's Avatar
greg 6746
Ttt
Old Apr 27, 2006 | 11:34 PM
wamara's Avatar
wamara
Cruise-In II Veteran
I was under the impression there are some adjustment screws inside the door that regulate the amount of travel, angle, etc. Maybe that would solve your problem; sorry I'm not more help. Good luck and let us know what your outcome is.
Old Apr 28, 2006 | 10:43 AM
TEXHAWK0's Avatar
TEXHAWK0
I think the window regulator tracks have adjustable stops at the top of the travel, but I don't remember seeing anything to adjust the downward travel.
The window may indeed be hitting something inside the door, but I don't think it can go down too far unless something is broken.
Old Apr 28, 2006 | 03:11 PM
greg 6746's Avatar
greg 6746
i took the door panel off and did not see any stops at the bottom of the tracks. their is a lot of slack in the cable. is it possible for the cable to stretch?
Old Apr 29, 2006 | 10:13 AM
greg 6746's Avatar
greg 6746
Ttt
To Need Help With Window
