Front leaf spring threaded inserts
Old Apr 27, 2006 | 08:00 PM
DeFormula's Avatar
DeFormula
Default Front leaf spring threaded inserts
Does anyone know where I can get a set of these without having them custom made or buying a complete new spring? These are the inserts that the adjuster bolt threads into. Thanks in advance.
Dave
Old Apr 27, 2006 | 08:08 PM
John Shiels's Avatar
John Shiels
From: Buy USA products! Check the label! Employ Americans
Karshop.com vendor here.
Old Apr 27, 2006 | 08:13 PM
DeFormula's Avatar
DeFormula
Thanks John. Once again, you da man!
Old Apr 27, 2006 | 08:25 PM
John Shiels
Hopefully he can get some out a damaged spring. He doesn't take credit cards guess send him a money order to speed things up. Good Luck Dave! Even a local junk yard if you are in a rush. Adjuster bolt you can get from Hardbar.net if you need those.
Old Apr 27, 2006 | 08:44 PM
DeFormula's Avatar
DeFormula
Yep. At your suggestion a few months ago I got the bolts from Hardbar. I went to put them in and noticed the inserts missing The holes look to be in good shape though.
Old Apr 27, 2006 | 11:17 PM
leaftye's Avatar
leaftye
You can get the inserts from Vette Brakes for about $8 each. These are the inserts for their extreme springs, but I assume the inserts are interchangable with GM inserts.
To Front leaf spring threaded inserts
