Active handling question - not what you think
Old Apr 28, 2006 | 08:28 AM
clemsondave's Avatar
clemsondave
Default Active handling question - not what you think
Yes, I searched and found tons of threads on Active Handling problems. I read through quite a few and they dont answer my question.
Does the 'Active Handling' verbage always light up when the tires lose traction?
I think my problems that I brought up in the FI section might be the tires spinning in 3rd, not the clutch or valve float. Not sure, just trying to eliminate possiblities. I have soft tires, so they do not squeel.
Old Apr 28, 2006 | 10:13 AM
2kbluestreak's Avatar
2kbluestreak
The "Active Handling" message will apear on the DIC momentarily if it is activated. "Traction Control" will also appear if it is activated. These are two similar, but different, events.
