Front end alignment #'s
Old Apr 28, 2006 | 08:59 AM
jimcork1's Avatar
jimcork1
Default Front end alignment #'s
Does anyone know the front end toe it or camber specs are for the C5.
I have checked mine and found +1/4 degree camber and 1/16 toe in and would like to know how this is vs. spec. Thanks 99 Nassau Blue
Also what are the recommended #'s to prevent inside edge tire wear.
Old Apr 28, 2006 | 09:50 AM
pro1955's Avatar
pro1955
If you do a search you will probably get more info than you want, Leaftye has a sticky up on top that has alignment specs its a great tool he spent alot of time putting it together. On my car caster 7 degrees, camber neg. 1/2 degree, toe 1/32 in.
Old Apr 28, 2006 | 10:16 AM
rws.1's Avatar
rws.1
I use the VBandP Advanced street settings.
IT really helps turn in and minimize tramlining... there is some inner wear compared to the rest of the tire...
http://www.vbandp.com/instructions/h...ruct/align.htm
Old Apr 28, 2006 | 03:43 PM
TEXHAWK0's Avatar
TEXHAWK0
If you want even tire wear and don't care much about handling, set the camber at 0 deg.
I backed mine off to -.25 to -.375 camber, and I get acceptable inside tire wear.
Old Apr 28, 2006 | 04:00 PM
VetteDrmr's Avatar
VetteDrmr
I have checked mine and found +1/4 degree camber and 1/16 total toe in and would like to know how this is vs. spec. Thanks 99 Nassau Blue
You should have about 1/16 total toe in and -1/4 degree camber. 0 or positive camber will wear the outer edges of the tires.
Also, don't forget the rear tires, which also have camber and toe adjustments. Go for 0 toe in and 0 to -1/4 degree camber.
BTW, gotta love the Nassau Blue!
HTH, and have a good one,
Mike
Old Apr 29, 2006 | 11:51 AM
jimcork1's Avatar
jimcork1
Thanks to all who replied. I appreciate the info.. 99 Nassau blue..
To Front end alignment #'s
