Engine Cutting Out After 2mph!!!!!!!!
Old Apr 28, 2006 | 11:39 AM
evasoukalova's Avatar
evasoukalova
Cruising
Default Engine Cutting Out After 2mph!!!!!!!!
My 2000 C5's Engine Is Cutting Out After I Reach The Speed Of 2mph.also,when The Engine Is Running And I Disconnect An Abs Sensor The Engine Cuts Out.can Anyone Of You Help Me With Problem.peter Kral From Czech Republic In Europe.
Thank You Very Much.
Old Apr 28, 2006 | 11:45 AM
Ikester's Avatar
Ikester
CI 6-7-8-9 Veteran
St. Jude Donor '08-'09
column lock problem is happening, get to a dealer!
Old Apr 28, 2006 | 01:43 PM
WKMCD's Avatar
WKMCD
Old Apr 28, 2006 | 02:09 PM
Icemanskis's Avatar
Icemanskis
Cruise-In VI Veteran
St. Jude Donor '05
same thing happened to me and it was a faulty column lock relay. this happened after i had completed the recall.
Old Apr 28, 2006 | 05:35 PM
Randy@DRM's Avatar
0Randy@DRM
Former Vendor
Try cleaning the little black thing on your key too. Sometimes that can cause the problem.
Randy
Old Apr 28, 2006 | 10:02 PM
schpenxel's Avatar
schpenxel
St. Jude Donor '15
^ happened to me the day I bought my car.. I was only 800 miles from home... talk about being freaked out haha. 20 years old, just flew out to St. Louis to spend all my money on a corvette, got a few hundred miles down the road and stopped for gas and had this happen when I started it/tried to start moving...
good times, good times...luckily for me the guy i bought the car from was a legit guy and always answers the phone when I call to ask him about a problem with the car...
Old Apr 29, 2006 | 01:29 AM
ajderzie's Avatar
ajderzie
Its a column lock failure on a car that has had the recall already done. The recall programmed the computer to cut at 2mph if the column lock failed. Dealer should fix for free.
Old Apr 29, 2006 | 01:34 AM
schpenxel's Avatar
schpenxel
St. Jude Donor '15
or its the pellet on the key not connecting properly...both solutions have already been stated 10x
Old Apr 29, 2006 | 08:33 AM
rws.1's Avatar
rws.1
Guys....
Kral says he is from the Czech Republic.... I doubt there are any Corvette dealers thee... the Vette was likely imported one off....
Recomendations? If the recall has been done... can he just intall a CLB?
Old Apr 29, 2006 | 09:58 AM
meldog21's Avatar
meldog21
Drive at 1 mph. Just kidding. I agree, steering column lock issue. I had mine fixed at the dealer under warranty.
Dog
Old Apr 29, 2006 | 11:01 AM
boosted_z06's Avatar
boosted_z06
Non American C5s I do not think came with CL.
You cannot have a wheel sensor broke or disconnected as the PCM would see this and to be safe prevents TAC for drive by wire to command throttle movement
Old Apr 29, 2006 | 09:34 PM
beltfed21's Avatar
beltfed21
Default Dealer can rip you off. Get the CLB!
Be carefull about going back to the dealer. I had a 2000 A4 that had the column lock recall done and then 6 months later got the SERVICE COLUMN LOCK with fuel shutting off at 2 MPH. After having it towed to the dealer, it ended up being the column lock motor itself, and they charged me $524! Yes, even though the recall renders the steering column unlockable. I bitched to GM, and bitched to the dealer, but got no where. They both said that the column lock motor itself is not added during the recall and therefore not a covered part. Lesson learned, never go to the dealer for column lock problems (especially on a 2000 which is seems to be more prone to the column lock motor burning out). Get the CLB!!! only $50.00 and easy to install following directions on this website. Good luck.
Old Apr 29, 2006 | 10:54 PM
dudleyd's Avatar
dudleyd
If he has the "service column lock" code on the DIC and it shuts down at >2mph I think it has to go back to the dealer to have the PCM re-flashed to remove the fault.
Old May 12, 2006 | 07:57 AM
redvetteman97's Avatar
redvetteman97
Default This is the same thing
Mine is in the garage with the same problem right now. I was told it will cost 600.00 .GM wiil not cover , I also had the recall done back in 1999. I no there not going to do anything about it. So what do you do ? You have to pay or the car wiilnt run. Sucks How GM can get away with this.
Old May 12, 2006 | 08:42 AM
Shane_S's Avatar
Shane_S
If the problem was due to the recall retuning the PCM, perhapse he can mail the PCM back to the states to get tuned by a mail-order tuner like LG or somebody, and then just install the CLB?
Shane
Old May 12, 2006 | 09:57 AM
CORVETTE FOR US's Avatar
CORVETTE FOR US
2nd Gear
Default Service Column Lock Display
i had the dreaded service column lock up message and the pull key wait 10 sec message car would die at 2mph.mine is a 1998 i had the car for three days needless to say my wife wasnt real happy . contacted gm
they were great rold me to get it diagnosed if it was related to recall done they would take care of it.which lucky for me i am good friends with a mechanic at local chevy dealer towed the car in and he found the problem in behind the fuse panel in the passanger foot well gm
took care of everything...
To Engine Cutting Out After 2mph!!!!!!!!
