12 disc cd install
Old Apr 28, 2006 | 01:27 PM
rbrtclk's Avatar
rbrtclk
Default 12 disc cd install
Purchased a factory 12 disc player from E-Bay. When installed the left channel is very weak. Transferred known to be good electronics from another unit to the newly purchased unit. Same problem still exists. Could there be a problem with the wiring harness, or the connections in the passengers footwell? Thanks
Old Apr 28, 2006 | 03:18 PM
C5forFun's Avatar
C5forFun
Same here, mine was lower volume on the left and now no volume. I hooked up the changer to another Coupe and it was the same, so I guess the changer is bad. His changer works fine, so the wiring was OK.
Old Apr 28, 2006 | 03:47 PM
screw991le's Avatar
screw991le
From: Redsox, Pats, Celts & Bruins !!! Redsox Nation !!!
St. Jude Donor '06-'07-'08-'09-'10-'11-'12
My changer did the same thing. Then I went the iPod route. Sounds ten times better and no sound issues.
Old Apr 28, 2006 | 09:47 PM
rbrtclk's Avatar
rbrtclk
Thanks, guess its bad.
To 12 disc cd install
