Rotor Specs
Old Apr 29, 2006 | 03:54 PM
dwalker011's Avatar
dwalker011
Default Rotor Specs
Does anyone have the specs for the minimum thickness on the front rotors on a 99' hardtop? Im trying to decide whether to resurface them or replace them but, I want to make sure there not out of spec. Thanks.
Old Apr 29, 2006 | 07:17 PM
John Shiels's Avatar
John Shiels
From: Buy USA products! Check the label! Employ Americans
NAPA 25 buck each new
Old Apr 29, 2006 | 08:18 PM
SpeedyZ's Avatar
SpeedyZ
Below are the GM specs for a 99 C5. But like John said, NAPA has new rotors at a very good price. You will pay at least $10-$20 each to have the old ones turned unless you know someone.
Front Brake Rotors
Rotor Diameter
325.0 mm 12.8 in
Installed Lateral Runout
0.07 mm 0.003 in
Thickness Variation
0.013 mm 0.0005 in
Front Brake Rotor Thickness
Minimum Thickness after Refinish
30.6 mm 1.205 in
Discard Thickness
30.3 mm 1.19 in
New Rotor
32 mm 1.26 in
Old May 4, 2006 | 01:05 PM
mannygmt2's Avatar
mannygmt2
cool..thanks for those specs...
i just bought front rotors at Napa for my C5 today, and i was wondering about the stock specs vs these Napa rotors...
I measured the NAPA front rotors, are 1.25" thickness. So i guess thats not so bad, and the price is very nice, not worth resurfacing them IMO.
To Rotor Specs
