New Shocks for Z06
Old Apr 30, 2006 | 10:23 PM
Roy Sykes
Guest
Posts: n/a
Default New Shocks for Z06
Is there a shock out there for a little softer ride in a Z06?
I know why buy a Z06, but love the FRC and the power.
Old May 1, 2006 | 02:02 PM
63Corvette's Avatar
63Corvette
Roy, shocks and springs are designed to work together in a set. You are asking for a softer shock. Well you can buy a set, but the design of the shock is to control the spring, and the softer shock won't do that well. I don't really suggest that you change the suspension, because that will lower the designed-in performance level of the Z06, but if you still insist, then go to Vette Brakes or other manufacturer and get springs and shocks designed to work together.
Old May 1, 2006 | 07:15 PM
Roy Sykes
Guest
Posts: n/a
Default Shocks
Thanks for the help.
Old May 1, 2006 | 07:55 PM
Just Enough's Avatar
Just Enough
Roy,
I tried Bilstein HDs on my Z and they gave a superb highway ride along with maintaining control of the car. I think the Bilstein HDs will give a Z a sport touring ride as opposed to a track ride. I ultimately went with 2004 ZO6 shocks for handling performance reasons. You will not be dissapointed with the Bilstein HDs, they are softer than the Bilstein Sports by about 15% and Bilstein Sports are similar in ride stiffness to the ZO6 shocks. Good Bilstein prices can be had at http://www.eshocks.com/
To New Shocks for Z06
