Changing to digital climate control possible?
Old May 1, 2006 | 11:11 AM
95BlueBomber's Avatar
95BlueBomber
Default Changing to digital climate control possible?
I am wanting to change my 99 to the digital climate control. Is this possible by plug and play or will it take more than that?
Old May 1, 2006 | 11:25 AM
birch64's Avatar
birch64
a buddy of mine tried and was told it would not work, would have to change the computer and wiring harnesses and sensors.......maybe someone else has more info....
Old May 1, 2006 | 11:39 AM
95BlueBomber
Thanks for the quick reply! Oh well I will just have to deal with it. Just nice to have bells and whistles.
Old May 1, 2006 | 02:35 PM
white90conv's Avatar
white90conv
The manual setup is more reliable. Changing systems not practical - it is much, much more than replacing the controller.
Old May 1, 2006 | 02:40 PM
MrEracer's Avatar
MrEracer
I may be the only person on the planet that has attempted this... First, I will say that it's not worth the trouble... To make this change you will need to change the following items:
Underdash A/C unit must be replaced complete with all vacuum lines and vacuum controls.
Underdash wiring harness must be changed to match the A/C unit.
Transmission wiring harness must be changed to match all connectors on the new underdash harness.
It may also be necessary to change the forward main wiring harness.
Add temp. sensor up near the horns.
Add the inside air temp sensor.
Add the dual zone A/C dash unit.
This is worse than changing from A4 to MN6...
Shirl Dickey
To Changing to digital climate control possible?
