driveline clanking sound
Old May 1, 2006 | 03:53 PM
rickkym's Avatar
rickkym
Default driveline clanking sound
I took out my center console and put a Z06 shifter in my 97 coupe. It has ~35k miles on it. Driving around without the center console I noticed a very loud double-clanking when the clutch was let out or the car compression slowed. Is this the torque tube going bad, it sure sounded like bad u-joints (I know the TT has rubber couplers).
Assuming the TT is going bad, how expensive/difficult is it to rebuild? And I could not believe how loud the driveline is.
Thanks!!
Old May 1, 2006 | 04:15 PM
ajg1915's Avatar
ajg1915
St. Jude Donor '08
I doubt it's your TT as you would have severe vibrations.
Could be yor throw-out bearing or something else loose.
Old May 1, 2006 | 08:18 PM
GotMe1's Avatar
GotMe1
Is it heard in the rear? I had a clunk noise in the rear and thought it sounded like a bad drive shaft sound but it was dry spline syndrome. Ther rear wheel splines get dry and the tiny tolerance in the spline make an amazing amount of clunky noise. Bit of grease and nice and quiet now
Old May 2, 2006 | 10:56 AM
rickkym's Avatar
rickkym
The sound was definately comming from the front. And it was a double-clanking sound. Whould that be a pilot bushing or the throw-out bearing?
Thanks!!
Old May 2, 2006 | 12:42 PM
ajg1915's Avatar
ajg1915
St. Jude Donor '08
You need to put a little more description to the problem.
Do you here the noise when the clutch is fully depressed ? partially depressed, etc ?
Have you checked to make sure all of your fuel. brake lines, etc are tight as they run through the tunnel. Also check all of your exhaust brackets.
Old May 2, 2006 | 02:20 PM
CarlScholdberg's Avatar
CarlScholdberg
2nd Gear
One of the guys in the club I'm in had a popping/clanking noise up in the front and it ended up being the bolts on the front part of the TT had worked loose.
Seemed to clank when he first accelerated or when he started to decelerate.
I dont remember him saying anything about a vibration.
Old May 2, 2006 | 03:21 PM
dmoss69's Avatar
dmoss69
Default clanking sound
Me and a friend of mine has corvettes, and ours have a clicking sound, about like a lifter tapping comming from under the hood, I figured that it was a common problem. Yall having the same sounds?
David
To driveline clanking sound
