When i start the car I get a annoying buzzing sound about 5 seconds after the car was started. You can only hear it at idle because the road noise drowns it out. I though it was an exhaust gasket leak but that was replaced. it almost sounds like interferance with the speakers but im not sure. Any thoughs would be apperciated. Thanks.
It's a "feature", the fuel pump is providing you with an audible signal to indicate that it is operational. Replacement is a bit of a hassle, after a while it becomes white noise.
