service traction & active handling
Old May 4, 2006 | 03:42 PM
rydis's Avatar
rydis
1st Gear
Default service traction & active handling
I have this fault codes on my 2002 vette. i have tried to reset them but they will not disapear.
28-TCS: c1225h c1226h c1227h c1228h c1248hc c1255hc c1282hc c1284hc c1285hc c1287hc c1288hc
c1291h c1296hc
Does any one have any tips to fix this?
Someone told me to check all the ground connections?
Old May 4, 2006 | 04:14 PM
dmcantrell's Avatar
dmcantrell
C1225 LF Excessive Wheel Speed Variation
C1226 RF Excessive Wheel Speed Variation
C1227 LR Excessive Wheel Speed Variation
C1228 RR Excessive Wheel Speed Variation
C1248 [not listed]
C1255 EBTCM Internal malfunction
C1282 [not listed]
C1284 [not listed]
C1285 [not listed]
C1287 Steering Sensor rate malfunction
C1288 [not listed]
C1291 Open brake lamp Sw Contacts During Deccel
C1296 [not listed]
http://www.stengel.net/diccodes.htm
This thread may be helpful : http://forums.corvetteforum.com/showthread.php?t=896875
and this one too: http://forums.corvetteforum.com/show....php?t=1381774
good luck!
Old May 4, 2006 | 04:34 PM
mannygmt2's Avatar
mannygmt2
c1291h c1296hc
good luck, i have been battling this one since last year,
Today, i had the steering position sensor (SPS) changed. After the new SPS was installed, the car failed some tests using the tech 2... they took the car for a test run, and now seems to be working ok. I am picking up my car tonight.
i was only getting c1287..and c1288... which is linked to the SPS...
yours might look like the EBCTM.. not sure, ... that is a $$$$ part to replace. SPS replacement was $300 for me.
will report after tonight how my car runs
To service traction & active handling
