Fan problems! Plez help!!
Old May 5, 2006 | 12:51 AM
SPD KILZ's Avatar
SPD KILZ
Default Fan problems! Plez help!!
Ok I had heat issues with my old motor, now i just put in a 408 and while doing so replaced EVERTHING. Dewitts, water pump, and termo and im still seeing temps a little higher then i should like in the 230 range.(I wont let it get past that) So I took it in the my dealer and had him check out the fans.... they told me i have a failure on the #1 fan. The company who did the motor install told me to replace the relay on the fan that is not working beofre I go and just buy a new set of fans. So the question is where is the damn relay and how do i replace it!? Any help would be apprecaited!
