Oil Filter On C5
Old May 5, 2006 | 09:41 AM
cazvette's Avatar
cazvette
Default Oil Filter On C5
I will be change my oil very soon and would like some insight on the location of the Oil filter and if its easy to get to or not. Thanks
Old May 5, 2006 | 10:25 AM
GWurst's Avatar
GWurst
http://www.c5forum.com/diy/oilchange.php
Easy to get to once the car's up in the air.
Old May 5, 2006 | 10:28 AM
01vetter's Avatar
01vetter
The oil filter is at the rear of the oil pan under the car. You have to get at it from under the car. Also, the oil drain plug is at the front of the oil pan. This means that you have to have the car level or higher at the rear to drain the oil. You will need ramps for the front and a jack to raise the rear to do the oil filter and change the oil. Not that difficult to change it.
Old May 5, 2006 | 11:36 AM
rws.1's Avatar
rws.1
BUT you also want either a second set of ramps or jackstands or concrete blocks to put under either the rear saddle or the rear wheels. You do NOT want to get under a car that is supported only by a jack...
Old May 5, 2006 | 01:02 PM
fixvet's Avatar
fixvet
Geez man, just get under your car and look !!
Old May 5, 2006 | 01:11 PM
Wicked Weasel's Avatar
Wicked Weasel
St. Jude Donor '05-'08
I bought 2 sets of ramps. drive up on the front ones and then raise the back with a jack and put the 2nd set under there. the car is at the right angle to drain the oil and there is plenty of room to get under the car without worrying about it falling on you.
Old May 5, 2006 | 03:32 PM
cazvette's Avatar
cazvette
Thanks everyone!!! Ive done alot of oil changes in my life and yes they're relatively easy, but I wanted to make sure of the easiest way before I went ahead and tried.
Old May 5, 2006 | 03:33 PM
cazvette's Avatar
cazvette
Thanks for the link, very informative!!!
Old May 5, 2006 | 07:20 PM
phils C5 vette's Avatar
phils C5 vette
St. Jude Donor '12-'13-'14
it's a bit of a bear reaching in from the drives side if the car isnt jacked uo enough. Get a good oil filter wrench.
To Oil Filter On C5
