rattling noise in engine
Old May 5, 2006 | 01:51 PM
trtprimo's Avatar
trtprimo
2nd Gear
Default rattling noise in engine
had new motor built . new afr heads new cam whole exhuast system, new 80 mm throttle body new intake new reprogrammed ecu.
now i check the plugs and they are white with red spots. and that rattling noise that sounds like a diesal engine any body has any clue on whats happening. thanks
Old May 5, 2006 | 02:00 PM
SFVetteman's Avatar
SFVetteman
Plugs are running very hot. Are they the right ones? If so, then it is probably running too lean and/or too much timing.
