Here's one for C4C5 or C5Tech
Old Aug 22, 2001 | 09:24 PM
Dave H's Avatar
Dave H
Default Here's one for C4C5 or C5Tech
Hi: Getting a current P0704 Clutch Switch Circuit-B Code and my Cruise Control stopped working. Suspect they're related but I'm not sure where to start looking. Wonder if it's the safety switch that keeps you from starting if you don't step on the clutch first? or? Help, I need the cruise control! Thanks for any suggestions. :confused:
Old Aug 22, 2001 | 10:13 PM
vetteshop's Avatar
0vetteshop
Former Vendor
St. Jude Donor '13
Default Re: Here's one for C4C5 or C5Tech (Dave H)
Probably a mis-adjusted or faulty cruise dis-engagement switch on the clutch pedal.Pull up on the clutch pedal with your foot while engaging the cruise control to see if it works.This is common with the cruise brake release switch also...
Old Aug 22, 2001 | 11:36 PM
Dave H's Avatar
Dave H
Default Re: Here's one for C4C5 or C5Tech (C-5 TECH)
Thanks C5tech. Will check it out tomorrow AM on the way to work. Will advise results :D :D :D
To Here's one for C4C5 or C5Tech
