XPipe Question
Old May 7, 2006 | 08:48 AM
Black 79's Avatar
Black 79
Default XPipe Question
My setup requires a 3" xpipe to connect to Stainless Works long tubes @ stock center to center width. It can be either 3" or 2 1/2" exit, stock width. It will connect to my 2 in 2 out Borla that takes the place of the normal rear end of the center section.
Any ideas are appreciated!
Thanks - David.
Old May 7, 2006 | 10:28 AM
sxeC7's Avatar
sxeC7
St. Jude Donor '06-'07-'09-'10
Are you deleting the cats or are you using HiFlo's and plan to use your rear O2 sensors? Sounds like you need 3" ID to 2 1/2" OD reducer pipes and Torctite clamps for lapped joints.
Old May 7, 2006 | 11:39 AM
Face's Avatar
Face
If you're looking for a offroad X, give www.drgas.com a call.
Old May 7, 2006 | 11:51 AM
Uncle John's Avatar
Uncle John
Custom made parts is no problem with Dr. Gas
Old May 7, 2006 | 12:27 PM
Black 79's Avatar
Black 79
I have 3" Dr Gas crossovers on a couple of Mustangs I have now; I thought there might be a piece already fabbed for the C5. Like the Mustangs, I want the xpipe as close to the collector as possible, but I don't think there will be enough room from the rear of the xpipe to the front of the Borla for Hi-Flow cats. I haven't taken the final measurements yet though, I might be able to fit a post xpipe cat in if I cut the in pipes to the Borla. I plan on deleting the post cat sensors in the computer.
Thanks - David.
To XPipe Question
