Ls2 Tb
May 7, 2006 | 12:53 PM
Ls2 Tb
How difficult is it to install an LS2 TB onto an LS1? (looking at having TPIS modify my LS6 manifold)
Is there a different wiring harness needed or just spicing some wires?
May 7, 2006 | 02:30 PM
You can buy a plug-n-play adapter harness or wire it up yourself if you're so inclined.
PIN ID LS2 90mm
A.) ACT2
B.) ACT1
C.) +5v TPS Reference – Common to both TPS’s
D.) TP1 Signal 0-5v
E.) Common Ground
F.) TP2 Signal 5-0v
98-04 Wiring hookup
A.) ACT 2 - Brown
B.) ACT 1 - Yellow
C.) +5 TPS Dk Green/Wht
D.) TP1 Signal – Dark Blue
E.) TPS GND – Purple
F.) TP2 Signal – Pink
May 7, 2006 | 04:17 PM
Where can you buy a plug and play,and what kind of cost are we talking about?
Are all of these wires located in the same area? (I'm a little confused)
May 7, 2006 | 04:59 PM
Check with Andy at A&A (forum vendor) for a harness. Afa the wires, they are for the TB connector.
David Farmer posted this a while back.
Pin
Wire Color
Circuit No.
Function
A
BN
582
TAC Motor Control - 2
B
YE
581
TAC Motor Control - 1
C
TN/WH
1704
Low Reference
D
D-GN
485
TP Sensor 1 Signal
E
L-BU/BK
1688
5-Volt Reference
F
PU
486
TP Sensor 2 Signal
May 7, 2006 | 05:08 PM
Contact
www.casperselectronics.com I believe they make one but it's not on their site yet.
May 7, 2006 | 08:04 PM
Thanks for the sites guys; I'll check the prices at both.
Patches;
The reason the wiring diagram is confusing me, is that I'm not sure what I'm going to need to do; Is the connector itself different and I just need to transfer the wires over, or am I "locating" some additional wires to install into the same connector?
May 8, 2006 | 12:39 AM
I believe Katech, Racetronix, and DTE also sell LS2 harnesses.
Mark
May 8, 2006 | 08:57 PM
