where is the headlight door control module?
Old May 7, 2006 | 01:50 PM
Mongolink's Avatar
Mongolink
Default where is the headlight door control module?
gotta test for voltage at he headlight door control moduale cause the doors wont come up and thelights wont go on. any help ?
Old May 7, 2006 | 05:05 PM
Face's Avatar
Face
I changed mine a few years ago. I could be wrong, but I believe it's under the driver's side headlamp. If not, it's the passenger side. You can access it from under the car. You remove the black plastic panel that's also used to access the turn signal assembly. Then look up. There should be a black box with a harness or two going to it.
Old May 7, 2006 | 05:16 PM
Patches's Avatar
Patches
Passenger side
Old May 8, 2006 | 12:18 AM
94legaleagle's Avatar
94legaleagle
Originally Posted by Patches
Passenger side
Yep, it's under the passenger side headlight - it bolts to the headlight bracket, and the headlight bracket is bolted to the frame.
To where is the headlight door control module?
