Computer relearn
Old May 7, 2006 | 02:16 PM
Pro Street's Avatar
Pro Street
Default Computer relearn
What fuses do you pull to do the computer relearn?Is it the fuse box underhood or inside in the footwell?
I do not want to pull battery cable and mess with resetting everything.
I just installed my Bassani X pipe and Borla Stingers and want the computer to relean with the new mods.Also put the Vararam on about 250 miles ago.
Thanks!
Old May 7, 2006 | 02:24 PM
debmwb's Avatar
debmwb
Since the mods are real mild, the computer will actually re-learn over time. I'd just leave it be and drive it.
Old May 7, 2006 | 03:00 PM
C_Williams@RPM's Avatar
0C_Williams@RPM
Former Vendor
Thanks!
You can disconnect the battery for twenty minutes and after reconnecting, the PCM will start from scratch rebuilding the L-Trims and S-Trims.
However, my experience with the Vararam is that you would be best off to have a tuner make some tweaks.
Charlie
Old May 7, 2006 | 08:51 PM
C5XTASY's Avatar
C5XTASY
Thanks!
Here's the "whole enchilada":
The car will re-learn simply by driving it between 50-100 miles. Or, the actual way to do it more quickly, is the following procedure:
1) Insert key into ignition and turn to the “ON” position, but, DO NOT START THE ENGINE.
2) Open the engine compartment fuse box cover and remove the two 10 amp fuses from position numbers 16 & 23.
a) According to the manual there are two fuse boxes. Use the engine compartment fuse block for this procedure not the instrument panel fuse block.
b) Engine Compartment Fuse Block (correct one): 16 is Powertrain Control Module A and 23 is Powertrain Control Module B.
c) NOTE: Your DIC will now display “check” messages for ABS, etc… Do not worry as this is normal.
3) Turn the ignition key to the “OFF” position.
4) Return to the engine compartment fuse box and re-insert both 10 amp fuses for positions 16 & 23.
5a) Idle relearn for an M6:
1) Start the engine and allow the coolant temp to reach a minimum of 176 degrees F. Allow the engine to run at this minimum temperature for at least 5 minutes.
2) After the 176 degree, 5 minute minimum run, shut down the engine for a minimum of 30 seconds.
3) Restart the engine and check for DIC error codes (there should be none).
5b) Idle relearn for an A4: (different)
2) Allow the car to idle in DRIVE, with air ON and then OFF, for 5 minutes each, and then in NEUTRAL, with air ON and then OFF, for 5 minutes each.
3) Turn the car off for at least 30 seconds.
4) Restart the engine and check for DIC error codes (there should be none).
6) Drive car for a minimum of 30 miles at varying rpm settings and speeds. PCM will now re-learn and adjust for the new air flow and temperature at the intake.
a) If error codes persist, repeat steps 1-7. Make sure fuses are properly inserted before repeating steps.
b) Do not deviate from the sequence outlined above. If you do, restart the sequence from scratch.
c) Steps 1-4 are also necessary if you ever disconnect your battery or lose power for any reason.
Ed
Old May 7, 2006 | 10:50 PM
Pro Street's Avatar
Pro Street
Thanks guys!
To Computer relearn
