Is this normal for battery drain?
Old May 8, 2006 | 09:18 PM
retriever's Avatar
retriever
Default Is this normal for battery drain?
I am having trouble with my battery draining from 12.5 to 12 volts in 5 days. I checked the drain with an amp meter. When I first hooked the meter up the draw was .4 amps after 15 minutes it dropped to .02 amps. The .02 amp should be ok for draw. Is it normal to have high draw for about 15 minutes after the battery is first hooked up. This is on a 2003.
Old May 9, 2006 | 06:28 AM
cenzo's Avatar
cenzo
Sounds normal Takes a few minutes for all the electronics to "go to sleep."
Old May 9, 2006 | 08:23 AM
99 vett babycar's Avatar
99 vett babycar
also, even when "asleep" the computers continue to "talk" to each other so the drain never goes to zero.
Old May 9, 2006 | 08:55 AM
ZO6vettepilot's Avatar
ZO6vettepilot
While checking the draw, was your underhood lamp illuminated? That will remain on for 15 minutes, then turns off.
Old May 9, 2006 | 09:04 PM
retriever's Avatar
retriever
Thanks for all the information. I did pull the feed for the underhood light.
Old May 9, 2006 | 09:43 PM
turboed's Avatar
turboed
what do they talk about?my computers must fight cause my battery will die in about 15 hours.
Old May 9, 2006 | 10:54 PM
vette747's Avatar
vette747
The C5 computers drain about 30 milliamps. The car can sit for 3 weeks and the battery should have enough juice to start the car.
To Is this normal for battery drain?
